7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
How do I connect the fiber optic loop to bypass the L7 amp?
I purchased an additional loop and the "adapter", but neither are compatible with the connector that goes to the L7 amp.
Bump
There are two connectors on the L7; a larger rectangular sliding connector which is power and a smaller square connector which is what you need to bypass. The part actually going into the L7 is an adapter of sorts so you need to pull out the smaller two wire connector and fit it into your MOST bypasser.
Ah, that was it, thanks a lot.
Bump
Can you bypass the L7 and still have sound?
Yes but only in the front speakers. No sub either.
Bump
Ok Yeah I'm trying to get the subs to play
Can you get you subs to play if you instal a most bus to stop the back doors from crackling and hissing
