7 Series - E65 / E66 (2002 - 2008)
Discussion pertaining to the flagship BMW here. |
Seat occupancy sensor disable Using NCS
If anyone is having the issue with the seat occupancy sensor, you can code this option out using NCS. Once you code the seat occupancy sensor out of the SSFA module you can clear the errors and the airbag light will remain off.
Change this in the SSFA or SSBF depending on the seat sensor that is failing: FOR SSFA From: BELEGUNGSERKENNEUNG_FA sbe1 TO: BELEGUNGSERKENNEUNG_FA keine_sbe FOR SSBF FROM: BELEGUNGSERKENNEUNG_BF oc3 To: BELEGUNGSERKENNEUNG_BF keine_sbe
Is one driver side and one passanger? Will restraint system have any issues in an accident or any other problems? I have a light for driver side on.
Sent from my Motorola Electrify using Bimmer App |
Nice job!
650i sport hud asanti af132 |
Great post!!! Move it to DIY section!
i don't see any of these lines in either the SSBF or SSBA modules, do i have to add those lines or what. having this problem and would like to code it off
Will this work for a short? My rear seat headrest go up and down whenever they feel like it. Usually when its hot out.
Hi
Would you please help me with the seat occupancy sensor? I did use NCSXEPERT to upload the SSBF module file. Then I modify the file FROM: BELEGUNGSERKENNEUNG_BF oc3 To: BELEGUNGSERKENNEUNG_BF keine_sbe, Load the file back to SSBF module. After that the light for Passenger Airbag went off for 20 sec and then the light come back. So then I reset the SSBF module with INPA. Went back to NCSEXPERT upload the SSBF module again and notice that the file is back to original, the keine_sbe is missing and the OC3 is back. I did it 2 more times with the same effect. Can somebody help me with this? 2006 BMW 750i GURTSTRAFFER_BF aktiv ZK_MIN_GURTSTRAFFER_BF wert_01 ZK_MAX_GURTSTRAFFER_BF wert_01 HALLSCH_EIN_GURT_SSBF hall_ein_gurt_an STROMGR_KS_HSCH_ZU_SSBF wert_01 INDEXTAB_FC_SSBF wert_01 STROMGR_AUF_HSCH_UB_SSBF wert_01 CHECKCTRLTAB_SSBF wert_01 ZK_MIN_AKTIVEKOPFST_BF wert_01 ZK_MAX_AKTIVEKOPFST_BF wert_01 TIMEOUT_ID_UEBERW_SSBF wert_01 VERZOEGERUNG_SBE_SSBF wert_01 LINKS_LENKER linkslenker PDC3_ERR_LIMIT_SAT wert_01 GURTSCHLOSS_BF aktiv ALGOPARAM_SSBF_EAM wert_10 AKTIVE_KOPFSTUETZE_BF aktiv BELEGUNGSERKENNEUNG_BF oc3 ZK1_ZF_SSBF vom_ss_nicht_beeinflusst ZK2_ZF_SSBF vom_ss_beeinflusst Last edited by badziewo; 01-18-2013 at 03:33 PM. |
Yes I did read it and was not there. But something did go in because the passenger light was off for 20 sec before I cleared errors with INPA. What I'm doing wrong?
