Parting Out
M5/M6 E60/E63 S85 engine parting out
Parting out M5/M6 E60/E63 S85 engine with only 32k miles, let me know if you want pics of a specific part. Prices are negotiable.
Cylinder head cover + profile Gasket ZYL. 1-5.......Qt.....1..part # 11127891022.... $250.00 Cylinder head cover + profile Gasket ZYL. 6-10...............1..part # 11127891023.... $250.00 Control unit for ionic current.........................................2. .part # 13627834713.... $150.00 AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids..........1..part # 11367841073.....$1,100.00 AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids.........1..part # 11367841074.... $1,100.00 Vanos Oil line + connecting line.....................................1..part # 11367838670+11367834573....$150.00 Vanos High-pressure pump + GEAR wheel + Sprocket.........1..part # 11367841784.... $1,100.00 PRESSURE ACCUMULATOR ( bracket available )................1..part # 11367834553.... $200.00 TIMING CHAIN............................................. ...............1..part # 11317834163.... $60.00 Vanos gearbox, inlet............................................. .......2..part # 11367835343.... $450.00 Vanos gearbox, outlet............................................ ......2..part # 11367838395.... $450.00 Adjusting pulley with lever with Belt tensioner...................1..part # 11287839133+11287835417....$60.00 Connecting rod............................................... .............5..part # 11247838623.... $100.00 Connecting rod + piston and rings...................................3..part # 11257840922+11247838623....$130.00 set of piston rings............................................. ...........4................$40.00 Flywheel.......................................... ..........................1..part # 21212229955.... $500.00 Clutch............................................ ...........................1..part # 21212283648.... $300.00 Vibration damper............................................ .............1..part # 11237834097.... $300.00 INLET CAMSHAFT.......................................... ..............2..part # 11317835879.....$300.00 CAMSHAFT EXHAUST........................................... ........2..part # 11317836125.... $300.00 Camshaft sensor............................................ .............4..part # 13627834490.... $60.00 Oil pump + suction pipe.............................................. ..1..part # 11417837613.... $450.00 Oil sump pump.............................................. ..............2..part # 11417834496.... $200.00 Engine wiring harness........................................... .......1..part # 12517838569.... $450.00 Actuator Idle control device.........................................2.. part # 13417834495.... $400.00 Fuel INJECTION TUBE + 10 fuel injectors.........................1..part # 13537834120+13647834893....$450.00 Actuator.......................................... .........................2..part # 13627834494.....$650.00 Throttle Housing Assy + Hall sensor................................2..part # 13547834831+13627841705....$450.00 Thermostat housing + thermostat..................................1..par t # 11517839062+11537836155....$250.00 Connector ZYL. 1-5................................................. ....1..part # 11537835220.... $40.00 Connector ZYL. 6-10................................................ ...1..part # 11537834051.....$40.00 I also have many hoses and lines, let me know what u need and Ill check |
Looking for BMW M5/E60 Engine Rod
Hey,
I came across your ad and wanted to see if you have a BMW M5/E60 Engine Rod and/or bearings? Thanks a bunch. |
Hi,
I have them. How many do you need ? all the rods comes with bearings. Let me know if you also need anything else. |
Got any wheels that will fit a 2000 540i?
no sorry
Interested in several parts - I don't have PM so e-mail me.
allmotor.2000@gmail.com Ionic control units specifically. I am in LA. |
Do you still have the
AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids..........1..part # 11367841073.....$1,100.00 AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids.........1..part # 11367841074.... $1,100.00 |
yes i still have them
send me an email to s.sha3lan@yahoo.com for further information.
bump
Can you mail me ,i am interested in the High Pressure Vanos oil pump and can you do a little with the price.Thank you. My email is miroslav@concepts.nl
Hi,
wondering if parts are still available. I am interested in the vans oil pump. (will these fit on an e60?) 4035619848 |
Clutch, Flywheel?
Hi,
Our 2006 M5 needs a new clutch and maybe flywheel at 118K miles. Do you still have these parts available? I am looking for the same parts that the new kits P/N 21212229955 and 21212283648 include. Photos of what you have would be great. Please email to 'jenssteinhagen at comcast dot net' or call me at two06-three31-nine989. How much would shipping be to WA 98020? Thanks, Jens |
Do you still have Throttle actuator? Let me know alex_skripalev@hotmail.com
Vanos
Hi
I need the following: 11367835343 / 11367838395 Please quote And send contact info Best regards Juan Carlos Lozano juancarlozano@yahoo.es |
M6
Hi
Mi name is Juan Carlos Lozano I'm a big fan |
update
I have the following parts left: block and crankshaft Cylinder heads Cylinder head cover + profile Gasket ZYL. 1-5 Cylinder head cover + profile Gasket ZYL. 6-10 Control unit for ionic current AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids (SOLD) AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids (SOLD) Vanos Oil line + connecting line Vanos High-pressure pump + GEAR wheel + Sprocket (SOLD) PRESSURE ACCUMULATOR ( bracket available ) TIMING CHAIN Vanos gearbox, inlet Vanos gearbox, outlet Adjusting pulley with lever with Belt tensioner Connecting rod Connecting rod + piston and rings set of piston Rings Flywheel (SOLD) Clutch (SOLD) Vibration damper INLET CAMSHAFT CAMSHAFT EXHAUST Camshaft sensor Oil pump + suction pipe Oil sump pump (SOLD) Engine wiring harness Actuator Idle control device (SOLD) Fuel INJECTION TUBE + 10 fuel injectors Actuator (SOLD) Throttle bodies Assembly + Hall sensor cyl 1-5 Throttle bodies Assembly + Hall sensor cyl 6-10 Thermostat housing + thermostat Connector ZYL. 1-5 Connector ZYL. 6-10 oil level sensor I also have many hoses, vanos hoses and lines, let me know what u need and Ill check |
all vanos gears sold, new list:
AT-adjustment unit (VANOS) ZYL. 1-5 + solenoids (SOLD) AT-adjustment unit (VANOS) ZYL. 6-10 + solenoids (SOLD) Vanos High-pressure pump + GEAR wheel + Sprocket (SOLD) Flywheel (SOLD) Clutch (SOLD) 2 Oil sump pumps (SOLD) 2 Actuators Idle control device (SOLD) 2 Actuators (SOLD) Vanos gearbox, inlet (SOLD) Vanos gearbox, outlet (SOLD) Block Crankshaft 2 Cylinder heads Cylinder head cover + profile Gasket ZYL. 1-5 Cylinder head cover + profile Gasket ZYL. 6-10 2 Control unit for ionic current Vanos Oil line + connecting line PRESSURE ACCUMULATOR ( bracket available ) TIMING CHAIN Adjusting pulley with lever with Belt tensioner Connecting rod Connecting rod + piston and rings set of piston Rings Vibration damper 2 INLET CAMSHAFT 2 CAMSHAFT EXHAUST Camshaft sensor Oil pump + suction pipe Engine wiring harness Fuel INJECTION TUBE + 10 fuel injectors Throttle bodies Assembly + Hall sensor cyl 1-5 Throttle bodies Assembly + Hall sensor cyl 6-10 Thermostat housing + thermostat Connector ZYL. 1-5 Connector ZYL. 6-10 oil level sensor |
bump
bump
bump
bump
1 Control unit for ionic current SOLD, 1 left
prices are negotiable so make me an offer
