E36 (1991 - 1999)
Old 09-05-2012, 08:34 PM
southpark11235's Avatar
southpark11235 southpark11235 is offline
bimmerfest Supporting Member
Mein Auto: 1999 BMW 323is
Messed up my shifter
I just finished installing new shifter bushing and putting car back together. I must of installed something wrong because neutral sits were 5th should be. Does anyone know what I screwed up so I can fix it?
Alex//1999 323is - power e46 M3 seats, style 43 rims, 328 exhaust, Z3 rack, Bilstein PSS coilovers
“We got about ten minutes before this entire county is up in flames. If you want to live, you’d better step on the gas! Oh wait is this a Tesla? Sh!t! Well, step on the prissy pedal, we're going to die!” – Cartman
Old 09-05-2012, 09:04 PM
Gooby's Avatar
Gooby Gooby is offline
Sexy Sax Man / Kebab Lord
Mein Auto: 1995 M3
Try rotating the shifter 180*
Instagram | @randytheus
Old 09-09-2012, 02:40 PM
Gooby you were 100% right the shifter was backwards. I turned it around and all the gears are where they should be. Thank you
Old 09-09-2012, 04:06 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
You aren't the first to do that, and you won't be the last. It's always kinda funny to hear the reaction when the installer realizes what they did wrong. So simple, yet so easy to do wrong.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 09-09-2012, 05:09 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i woulda just switched the '5' to the middle, and put an 'n' there....
df
Old 09-10-2012, 11:24 AM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
I'm really confused. Do you have any pictures?
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by hornhospital View Post
Jared, why don't you just put "It's Giubo" in your sig? Save a lot of typing.
Originally Posted by e36 miguel View Post
this jared guy sounds intimidating lol.
2005 X5 4.8is Le Mans/Black/6spd Steptragic SOLD 3/2016
1997 328iC Schwarz II/K/K 5MT SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6MT RIP 04/2011
Old 09-10-2012, 12:02 PM
B_Rad_M3's Avatar
B_Rad_M3 B_Rad_M3 is offline
I6 feels good
Mein Auto: POS
WAIT!!!!!!!!!
The PO (my car) had a new clutch installed, could that of messed with the shifter sitting towards 5th gear?
How can you rotate the shifter?
I'm sooooooo
At first im thinking shifter linkage and bushings, i just heard of a thing called a detent and now i might need to rotate it 180*!!!!
Old 09-10-2012, 01:30 PM
I do not have pictures from when the shift lever was backwards. So I took some pictures with the shifter about where it was when it was backwards.
Originally Posted by Brad31late View Post
WAIT!!!!!!!!!
I'm sooooooo
If the PO installed the shift lever backwards like I did it would make the shifter sit towards 5th. I have attached a picture of the shifter linkage with the part you need to rotate circled. To rotate, first remove the shifter knob, leather boot under it and the foam under that. Next pull up the rubber boot so it is no longer siting in metal circle. Then crawl under the car and remove the two clips on the selector rod. Now remove the selector rod and rotate the shift lever. Before you put every back together I would put the leather boot and shifter knob loosely on with selector rod installed without clips to see if the slither is where it should be.
ID:	341240   Click image for larger version
ID:	341241   Click image for larger version
Old 09-10-2012, 01:35 PM
petriej's Avatar
That is awesome. Thank you.
GGC BMW CCA #443004
Join the BMW CCA!
Old 09-10-2012, 01:46 PM
B_Rad_M3's Avatar
I6 feels good
Mein Auto: POS
Thank you good sir
First pic is neutral, second pic is 2nd gear, which is the exact way yours was...
ID:	341244   Click image for larger version
:3
