E24 (1976 - 1989)
The BMW 6 Series (E24) was the first variant of the 6 series produced by BMW from 1976 through 1989. |
m6
i have a 1985 m6 european model. it wont start but if i spray starter fluid in it it will run all day .what is the problem with my car
Fuel pump working? (can you hear it when the key is on?)
Quotes to live by: guessing gets expensive...drivinfaster nothing is more expensive than a cheap BMW...c4harpe13 Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff BMW-CCA #441426 1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia" I NEED A NAP, DANG IT! |
the car will run until you shut it off then it wont start unless you spray it with starter fluid
could be a cold injector valve. replace it or hot wire the external butron for it.
i have replaced the cold start valve and the blue temp sensor , where is the external button for the cold valve.i also noticed the fuel pump
Be careful, there are 2 fuel pumps back there. One internal to the tank which works as a supply pump to the external fuel pump by the tank. If either one of those doesn't work then the engine may not get fuel. Also, make sure your fuel pump(s) relay is working. Those can sometimes fail on you.
Can you give us a run down of what you have tried so far? It will help us to understand so that we can help you. Thanks, Eric |
it was the crank sensor
