Discussion pertaining to the flagship BMW here. |
Battery registration DIY
you all know that the battery needs to be registered when you replace it , in
these thread i well show you how to register new battery with INPA or toolset32 and this is just for REGISTERING THE SAME SIZE BATTERY first with INPA Last edited by Dead; 09-09-2012 at 05:20 PM. |
with toolset32 first go to file then click F3 then select POW_E65.prg in the second pic double click the command (steuern_batterietausch_registrieren) just ones and you are done . remember this is for registering the same size battery not for retrofitting another size , if you want to retrofit 90AGM battery you need to register the battery with DIS because DIS well register only 90AGM battery , if you want to retrofit another battery size you have to use NCS expert . |
We always used inpa. Should i use both or registering with inpa is enough
registering ones is enough , some ppl have problem with INPA registering there battery so i put toolset32 .
Good to know that you can also do that with ToolSet32. Thanks for sharing!
FYI: I cannot see the first 5 pictures. Maybe it's just me. |
I cant see them either..... it's not just you
![]() Ace
Yep, no photos on first five uploads. Let me know if you need help fixing this, then I will sticky
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
sorry guys pics uploaded again .
Thank you
So this battery should register with INPA/Tool32 ok then
My 760Li - Fully Loaded ![]() |
Help me out here? what is this battery thing ( registration ) with what? the car computer ?
So if you take out the battery and say get a sears diehard gold . what happens can someone explain . will another battery work ( doesn't it just see a 12 volt power supply? diehard $100 bmw $200
2006 750LI 19" Wheels-Conv pkg-Lux seat pkg-Prem sound pkg Cold Weather pkg-R sunshades-Satelite radio +A 1998 740IL |
U need AGM battery. It must be registered. Otherwise it wont charge properly. Our cars are very sensitive. If ur battery is low or doesnt get charged properly u will get different errors and faults. Ur car need to know how it needs to charge battery thats why u need to register it. U can go to dealer, INDY, or u can set up bmw tools and do it urself
100$ difference isnt that much compares to the price of other sensors modules etc. i would go with bmw battery but many ppl go with aftermarket and they are ok
thanks comrade
Np
This method is usefull only when you replace the battery with the same power - 95Ah.
But what if you want to replace it with 110Ah? |
Who has used a non OEM BMW Battery @ $300? I buy all my batteries from auto zone (warranty = 8 years). I am looking at replacing my 03 745i battery with a Duralast (for my specific year & model = same size!) auto zone battery! I am having my local dealership register it!
I've used nonBMW battery on my 745 2002: Varta Silver Dynamic 110ah. It cost me about 150 USD. The only important thing was to register the higher Ah, and my friend has done it for me, but i dont remember how - with DIS, INPA or somehow other way.
how or where do you get these different programs? do you need to hook up a laptop to the car
So guys, I just bought a 2004 745Li from a car dealer here in town. He did put a new battery in the car. Now I am getting a fault message, "Dynamic Drive Inactive" about every 3-5 days.
1. He is not a BMW dealer, just used cars. So, he would probably not know about this? If my message is from the battery not being registered, how would go about explaining this procedure to the dealer? 2. Could this be causing my problem with the fault message? Thanks! So, took my car back to the dealer, and the tech came out and hook up the machine, found the battery had not been registered! He made the comment, learned something new today! So the battery is registered with the car now. I hope I don't see the "Dynamic Drive Inactive" or any message now! Regards, Allan
Regards, Allan Last edited by fabecton4570; 11-25-2012 at 02:44 PM. Reason: Reason Resolved |
registering battery
I have not registered the battery I replaced on my 745i. I found that if you attached another battery ( I used my 325i) to the battery jumping poles under the hood of the 745i. That way the car never lost battery power while I was changing the battery. I bought the battery from NAPA and I have had no problems.
I dont know what ANY of this stuff means,..I just wish I could learn to POST stuff this neatly!
Fun Doesnt Come Cheap! |
I put an after market batt in and didnt register it now my radio and nav screen is going bezeerk ano my transmission is shifitin hard and my transmission failsafe indicator is coming on when it shifts hard its reading code p1885 solenoid short to ground will the batt cause this
#25
'11 328i '03 745Li '03 Acura TL-S '02 Infiniti QX4 |
