The X5 SAV Forum
Old 09-11-2012, 07:05 AM
TOOT77 TOOT77 is offline
Mein Auto: X5
Red face rear turn signal
My right turn signal inside the car blinks very fast. Is it a hard job to replace the rear turn bulb in the rear? If so Are there in pictures or video to show or is it best to have it professionally done? Thanks
Old 09-11-2012, 07:17 AM
watchurself watchurself is offline
George
Mein Auto: 2002 bmw 4.4i x5 sprts pg
no its easy as Pie - although you might not need to replace it as i had this issue recently
passenger side turn single was same as yours blinkikng fast -so i looked - no lights on the back turn single
light in front was fine - so i open the hatch and surprisingly (to me ) the connector had no wires?? i found this odd so i looked at the other side (drivers side) same thing no wires - weird huh??
so i grab the little plactic thing turn it and remove - look at it and notice the plastic bulb holder has 2 metal contacts on the frontside - so it must connect to the opening with these contacts
i checked my bulb and didnt see its filament broken or anything so i replaced it and turned it in place - tried it again and it worked
may have been jarred loose by a bump or something - so the contacts must align properly otherwise your light wont go on - it happened a couple more times on me and i fixed it both those times also -so just check to make sure your bulb holder is properly aligned with the socket
GEORGE
"EVERY FORM OF REFUGE HAS IT'S PRICE"
2002 4.4i BMW X5 - 166K Topaz Blue Ext/ Tan/Beige Leather Int
1994 Nissan Pathfinder SE 132K Black Ext / Grey Leather Int
Old 09-11-2012, 07:29 AM
Mein Auto: X5
Thanks!!!!!
Great news thanks!!!
Originally Posted by watchurself View Post
no its easy as pie - although you might not need to replace it as i had this issue recently
light in front was fine - so i open the hatch and surprisingly (to me ) the connector had no wires?? I found this odd so i looked at the other side (drivers side) same thing no wires - weird huh??
So i grab the little plactic thing turn it and remove - look at it and notice the plastic bulb holder has 2 metal contacts on the frontside - so it must connect to the opening with these contacts
Old 09-11-2012, 07:38 AM
George
the turn signal bulb holder is the white one -good luck
if you need a new bulb you can get it at any autoparts store -just look up the bulb #
GEORGE
