Discussion pertaining to the flagship BMW here. |
MISFIRE On ALL 8 CYLINDERS HELP
BMW is trying to charge me $7000 to fix my 2004 BMW 745Li because it is "Misfiring" through all 8 cylinders. They're also stating that my secondary air system has a fault. My car has 69K miles on it and I've had the coils and spark plugs checked already. Please help!!!!!!!!!!!!
Post this in the e65 section
97 740i e38 - SOLD 02 745i e65 03 Montero Limited ![]() |
So how did it happen??? Just out of nowhere??? I guess valve cover gaskets are leaking causing misfires bc coils are flooded with oil. What does the dealer say?? |
Won't drive if it needs all 8
Repairs 2012 wishbone & steering rack Rfmd hydro steering gea combination nu Ball Joint Tension strut with hydr Switch unit steering column Coils 5&7 and new spark plugs Faulty DSC Control Module Fuel Gauge Leaking Crank Case Vent Valves Power Steering pump, washer pump and grommont, Crank Shaft position sensor Total $13,481.37 in one year my mechanic swears all these parts are re engineered to work better than the originals lol
*****************CHECK YOUR PCV VALVE...ITS ON THE TOP OF THE VALVE COVER..SHOULD BE 2 (one on each)......try this: Idle the car, open oil filler cap, there should be A LIL bit of vaccum/suction.. if it stalls out, then they are bad...$70 for both at the dealer..
Im a Mechanic and tried new coils, plugs, compression check and ALMOST changed the computer ($900)...03 745Li misfire cylinder 2 with fuel cut-off now she idles CRAZY SMOOTH......any questions let me know Good Luck |
*******************CONTINUED********************
forgot to explain what was happening.. when they go bad, there is EXCESS pressure in the crankcase which was throwing off the crank sensor, therefore sending the wrong signal...as SOON as i replaced them, it started up like nothing happened...She used to stumble at idle and worse when in gear at a stop light. But u WOULD NOT feel it as u drove or even put your foot down...just at idle |
