E30 (1982 - 1993)
Old 09-12-2012, 05:07 PM
goat88 goat88 is offline
Mein Auto: 1989 BMW 325I
Battery drained?
Last week I was driving my 89 325I to work when the headlights and the instrument panel lights started to go dim, then a few blocks down the car dies, i took the battery in to be tested and it was dead, so I had the battery charged and it tested good, I pulled the alternator out and it tested good as well, where should I start looking to find the source of the charging issue?
Old 09-12-2012, 05:16 PM
longterry longterry is offline
Mein Auto: 2002 540i
I was having similar problems with my 540i and tracked it down to my FSU sensor. My sampling fan for the climate control was not turning off and draining my battery down. I ordered one from BMW and installed it and my charging problems were no longer an issue.
Old 09-12-2012, 11:40 PM
BMWFatherFigure's Avatar
Old School
With a DMM and ALL systems off (including boot and interior lights, radio and clock) set up and read battery drain current (if there is any). The charging problem could be a bad terminal related to battery charging. A bad terminal can be 'seen' by the alternator as a fully charged battery. Double check and clean all connections. then check charging voltage and current.
Current:
E38 Parts Car
Previous:
Old 09-13-2012, 01:33 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
certainly will be an issue between or inclusive of the battery and alternator. No E30 curcuit would drain a battery faster than your alternator can charge the car. But i would lean towards the alternator being dodgy, as an E30 will run off just the alternator with no battery installed (i have driven E30s i plan to wreck back from picking them up to my house with no battery installed, just a crash start or jump start), which reflexively means that if the battery was stuffed, the car would not have died while driving. Who tested your alternator?
E30 above Sold
Last updated 2nd January 2014
Old 09-13-2012, 09:26 AM
The alternator and battery were both tested at autozone
Old 09-13-2012, 06:51 PM
Bandem Bandem is offline
Mein Auto: BMW
Maybe you meant you have a generator? An alternator is impossible to start with a rolling-start or push without a battery or some electrical power source if thats what you meant by *crash start*.
Old 09-13-2012, 06:57 PM
downhiller's Avatar
livin large
there is no generator on an e30. its an alternator. and yes you can start/run a car with a dead battery by crash start. we've done it multiple times with different vehicles, but mainly jeeps.
also i was thinking some more, how does the car run without the headlights on? seem to charge ok?
Old 09-13-2012, 09:19 PM
Mein Auto: BMW
Thats physically impossible. Your battery in that case, was not fully dead. There is no way an alternator can start without an electrical power source. It has no permanent magnetic fields and therefore needs electrical current at certain voltage to excite the fields.
If you were able to start it through a push, it means your battery still had some juice left in it. Maybe even a miniscule amount, not enough to start ignition or run accessories, but enough to get the alternator going.
Old 09-13-2012, 09:31 AM
When it died on the highway an officer gave mine a rolling start and it ran as long as the rpms were kept on the high side down to the gas station but the whole way there my headlights were dead and my guages were barely lit up
Old 09-13-2012, 06:07 PM
Old School
Sounds like a main feed or earth to the whole vehicle. CAREFULLY check major connections. Even if they look good!!! Clean and tighten the terminals and check where the wire goes in, and next to, the crimp(s).
Current:
E38 Parts Car
Previous:
Old 09-13-2012, 06:37 PM
downhiller's Avatar
livin large
either a bad/loose ground or the alternator is about to crap out
Old 09-14-2012, 12:01 AM
Even with the headlights off that next day when i checked the battery they said it was at 85% charge, so i put it in and drove it about a mile down to autozone to check the alternator and was told the battery was reading at 60% so they couldnt test it then
Old 09-14-2012, 12:49 AM
Old School
You need a small current to excite the alternator but current and voltage that will increase with rotation speed. Push car ONLY replaces starter motor. Running without a battery can blow diodes but it does keep running - for a time. If your battery went from 85 to 60% it is not being charged by the car. Back to checking leads, terminals and connections.
Current:
E38 Parts Car
Previous:
Old 09-14-2012, 01:43 AM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Post Test procedure
Don't you have Autoelectricians where you live
All you do is connect a serious Amp meter between Positive & terminal, then pull that terminal from the Battery and see the charging or discharging current.
In Africa, any genuine place that sells you Automotive Batteries will check that, as well as Electrolyte and load test on the battery. Normaly they will not even charge you (pun intended), if you do not stand around wasting their time
THEN you eliminate what is wrong
Battery- OK
Alternator OK
Not charging- lookie look for problem
Draining battery with ingnition off- boot light or similar being on when it should not
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 09-14-2012, 02:45 AM
Thanks for the responses, once this rain clears up here I'll start checking connections and get back with you all
Old 09-14-2012, 11:46 AM
Well it turned out the alternator was going bad, i ended up taking it to my mechanic for a second opinion and he said it was failing under load, so I replace the alternator and it seems to be running fine now with the exception of the idle which is a little choppy and whenever i rev it up a little and let off the gas the engine nearly dies and then the rpms jump back up to around 500, is it possible i messed up zomething when i reinstalled the air box and air flow meter?
Old 09-15-2012, 05:32 AM
Old School
goat88 - Check CAREFULLY for leaks/damaged hoses on EVERYTHING you disconnected or 'moved'. Older car hoses crack or split very easily..
Current:
E38 Parts Car
Previous:
Old 09-15-2012, 06:37 PM
Well I checked the vacuum hoses for leaks without any luck and i honestly couldnt hear a leak either, most of the hoses look fairly new, i did retighten the hose attached to the icv after cleaning it out and that seemed to smooth out the idle some but the issue im still stuck on is when i start the car it will fire up like normal but as the rpms slow down to idle it eother seems to struggle with staying running or it dies, it also dies when im driving and i stop at a light when it would normally go down to idle it dies then too
Old 09-16-2012, 02:53 AM
From what ive gathered from various scources an alternator can self excite, when spun above a certain rpm range
Old 09-16-2012, 11:39 AM
hornhospital's Avatar
D'oh, You Kids!
Links to said sources, please. Only alternators with permanent magnets (in other words,not those used in automobiles) can self-excite. On all others, no matter how fast they are spun, they will not spontaneously start creating electrical energy.
Quotes to live by:
Old 09-16-2012, 07:58 PM
D'oh, You Kids!
Click the link that johnf posted and see what that says about the rotor of an alternator. It is NOT a magnet until it is energized by, guess what, the excitation voltage through it. And the test you got at Advance? Guess what the two wires to the alternator did before they started pulling current out of the spinning alternator? Yup...sent excitation voltage into it. Of course you'll get 14ish volts off a running alternator if you pull the wires. You already had it started with excitation voltage before you pulled the wires. An alternator's excitation voltage is self-sustaining once it's producing current.
I'm not trying to be an ass either, but I know alternators and electrical systems. I've been working on them for forty years.
Sent from my MB860 using Bimmer App
Quotes to live by:
Old 09-17-2012, 12:01 AM
Well if you read the whole article on wikipedia regarding automotive alternators its says plain as day that they can self excite, the other "various sources" i used was to confirm that it was a true fact
Old 09-25-2012, 12:07 PM
Mein Auto: BMW
Alternators used in automobiles are not self exciting. You CANNOT start a vehicle with an alternator without a excitation. hornhospital is 100% correct. In fact, i'm not sure, but I believe on many BMW's they have a minimum voltage requirement set to start, otherwise it won't even let you try.
I'd like to see a video of a car with an alternator and manual transmission being push started without a battery or some power source.
Old 09-17-2012, 04:47 PM
downhiller's Avatar
livin large
but it also mentions alternators that self excite after a certain speed, so if they can self excite, that means there has to be a magnetic field to start with, correct?
Old 09-17-2012, 12:06 AM
Anyways I figured out my idle problem it turns out that when I was removing the air box I pushed a radiator hose into a cluster of wires and 1 of them came undone (poorly reattached harness) so a little electrical tape and wire strippers fixed that problem, but once again my battery is draining out the alternator is brand new and its still not keeping a charge to the battery so I'm back to checking wires again :/
