BMW Coding and Programming
Discuss coding options and features on your BMW here. |
HUD Turn Signals
I am trying to activate the HUD turn signal in my 2013 535ix.
1. HU_NET / HUD_TURNSIGNAL = aktiv 2. KOMBI/BLINKER_HUD_ENABLE = aktiv There is no checkbox that shows up in the HUD settings. I have also found that the HUD_TURNSIGNAL is not in the 3000 HMI section as shown in the cheat sheet, but is in the 3001 EXBOX section on my car. Any ideas from the gurus?
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner |
When I enabled it; you had to click on "display options" first, then it gave you alist of itmees you can check, and uncheck; the "display Options" (maybe exact text is different) looks like a title for that menu, but when you select it, it brings up a bunch of things you can show or hide on the HUD, turn signals will appear in that list if you did everything right
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickrŪ |
No Sorry - I'm a 2012 Nov15/2012 build...
Ok. We need someone else with the new HU_NBT to see what is going on.
Paging @falcongeek ...
I did some digging a while ago and couldn't find any additional settings that I though needed to be changed, but it is possible that I missed something. Adam |
The checkbox on the HUD display options is not coming up with the turn signal checkbox. I have checked the coding multiple times and it shows in the HU_NET and KOMBI that they are aktiv.
What are the CAFD File names for your HU_NBT and Kombi ECU's?
kombi - cafd_00000069_009_000_042
2013 535i xDrive, Imperial Blue Metallic, Oyster and Black Nappa Leather, ZCW, ZDA, ZDH, ZLS, ZMP, ZPP, ZTP, 2TB, 323, 416, 4CE, 4U1, 5AC, 677, JB4 Tuner Last edited by Ionic202; 09-13-2012 at 03:46 PM. |
ive set today the KOMBI/BLINKER_HUD_ENABLE to aktiv but not the second one.
id no access to internet while coding so i could only watch some pdfīs i got currently ive the checkbox for "Blinker" in settings but no Blinker in HUD while driving around i try to set the other option to aktiv too and will report |
Well, it could be different in 2013, but I highly doubt it. Just to make triple sure though, please check the following:
1) Code KOMBI / BLINKER_HUD_ENABLE = aktiv - This actually enables the feature. 2) Code HU_NBT / HUD_TURNSIGNAL = aktiv - This adds the iDrive Checkbox to toggle the feature on and off. 3) Go into iDrive HUD Settings, and enable checkbox for Hud Turn Signals as shown in attached picture.
2) yes 3) no check box on settings screen.
What options are shown on your HUD Settings Screen? Can you post a picture of it?
It is the same as prior to coding.......
Hey guys, I had the same issue with my 2013 535i as well. I figured it out eventually. You need to set one of the PIA options to aktiv (I don't remember the name). I will post it here once I get home.
Pia_Default_Tippblinken http://www.bimmerfest.com/forums/sho...182&highlight=
Mine is F10 2013 with the new Nav. I'll keep you posted.
Good deal. Thanks.
Here it is:
1- Code KOMBI / HUD_PIA_BLINKER = aktiv 2- Code KOMBI / BLINKER_HUD_ENABLE = aktiv 3- Code HU_NBT / HUD_TURNSIGNAL = aktiv The iDrive check box will not show up, but it works. (I couldn't figure out the check box issue)
2013 535i xDrive M-Sport Graphite 2011 X3 35i White 2004 325i Silver Grey 1978 518 |
Adam |
![]() 2013 ///M5 Alpine White · Sakhir Orange Full Merino Executive · Driver Assistance · B&O · 20" HRE P40SC · Akrapovic Evolution · H&R Springs · Many Euro Mods |
#25
Did you only change the KOMBI / HUD_PIA_BLINKER = aktiv and nothing else to get yours to work? I have not tried that yet. I've also always set HUD_BLINKER_ENABLE to aktiv too. When I just reset HU_CIC / 3000 / HUD_TURNSIGNAL back to inaktiv (leaving the other 2 changes intact), the check box goes away and no signals in the HUD. I think the HU_CIC change just enables the checkbox on the screen and the KOMBI change(s) actually enable the function. |
