Old 09-18-2012, 05:28 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Average Tyre Life
I know this is a vague question, but say if you have mix of city and highway driving, what is the normal average minimum and maximum tyre life you guys have seen on your E60's? Please contribute min, max, tyre make and model.
1. 25000
2. 30000
3. 35000
4. 40000
5. 45000
6. 50000
Thanks.
Old 09-18-2012, 07:06 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
It can vary significantly depending on the tire and type of driving. Aggressive driving [and not rotating the tires] will lead to more trips to tire store.
Old 09-18-2012, 07:18 AM
phlfly's Avatar
phlfly phlfly is offline
Mein Auto: 07' 550i
I will never rotate tires it's not helping to longer life, it's making you pay more and for almost same tire life span.(you may getting extra 5,000 miles at most) That's what american consumer doesn't know, it's myth. It's cheaper just to replace two tires then all at same time.
It's scam by tire manufactures.
BMW CCA Member, Capital Chapter
HPIA4v2 HPIA4v2 is offline
Mein Auto: E60, E71, E92
I'd say depends on the tires as well, some all season has very soft compound and wear faster (less mileage). but in general terms around 30k-miles, I don't like driving with semi-bald tires in Seattle area (it rains 8-month out of the year here, I mean 8-straight months total!)
Old 09-18-2012, 11:42 AM
hooch999 hooch999 is offline
Mein Auto: 550i
1. 25000
2. 30000
3. 35000
4. 40000
5. 45000
6. 50000
Thanks.
My all-season Michelin Pilot AS rears lasted just 15K on my 550i, fronts would be probably in 20-22K area, but I replaced all 4 with summer Bridgestone Potenzas - hard to tell yet what mileage I get, but ride became substantially harsher.
Old 10-09-2012, 02:10 AM
kskane's Avatar
From DownUnder
Has anyone had the problem where the front tyre's are wearing off from inside faster than the outside. I have had two changes of tyre's and wheel alignment was done on both sets of tire, but the front one keeps wearing off from inside. Is there something else wrong?
Old 10-09-2012, 07:11 AM
Mein Auto: 550i
Check your control arms.
Old 10-09-2012, 04:51 PM
kskane's Avatar
From DownUnder
I am sorry but I don't know much on these, what should I check on the control arm? Are you referring to the bush, other than the bush what else can I check on a metal rod?
Thanks.
Old 10-10-2012, 05:35 AM
kskane's Avatar
From DownUnder
Guys, any help is welcome. Apart from control arm bushes, is there anything else I should for the above problem? Tyres are due soon, so I need to know how to stop the uneven inside wear on the front.
Old 10-09-2012, 05:32 AM
phlfly's Avatar
Mein Auto: 07' 550i
I have same thing, even BMW dealer did already three times wheel alignment. I guess it's sport packg aftermath. The car sits lower so heavy weight from V8 make wheels worn this way.
Old 10-09-2012, 08:26 PM
luilui41 luilui41 is offline
Mein Auto: 2006 550i
Staggered Continental DWS on my 550, about 20-25k for the front and maybe 10-12k for the rear
Old 10-10-2012, 05:20 AM
phlfly's Avatar
Mein Auto: 07' 550i
This is really low, do u race on them?
I have same set up fronts (Bridgestone) around 30,000-35,000 and rear (Yokohama Advin S4) now is 14,000 miles right on half of life, I guess I can get another 12,000.
Old 10-10-2012, 06:28 PM
On the front ones I can probably get another 5000 or so, but my rear ones go bad fast, specially since they come with a negative camber the inside of my tires are gone before the outside reach even half life
Old 10-10-2012, 07:59 PM
phlfly's Avatar
Mein Auto: 07' 550i
I do 3-5 psi higher then on door sticker.
Old 05-02-2014, 01:12 AM
kskane's Avatar
From DownUnder
Old thread, but its time for new tyres again. Anyone used Hankook tyre and know they are good?
Old 05-02-2014, 05:45 AM
javvy javvy is offline
Mein Auto: 2007 530Xi
I just installed Khomo Escta PA13.....they have rebate going on and they are nice.....best bang for your buck provide you find em in your size....I bought em from threaddepot.com.....if that helps..
javvy
Old 05-02-2014, 06:37 AM
maxxym maxxym is offline
Mein Auto: 2010 528i
I had those Khomo tires on my e39. Worst tire ever. After a while, they became so loud that it sounded like I was driving in a lifted 4x4 with snow tires on.
Old 05-02-2014, 07:59 PM
kskane's Avatar
From DownUnder
javvy
Thanks, would be good to know how long they last. KU36 are quieter tyre compared to KU31's, so I guess you like them so far.
Maxxym, do you know which Kumho's you had? KU22/KU31?
I hear Michelin part owns the Hankook, so was wondering.
Old 05-05-2014, 04:37 AM
So far I like the Kumho's...I guess they behave differently of different cars...I bought em cause I read a great positive review on tyrerack and that reviewer had the same exact car as mine a 530xi....plus the price was perfect.....plus I dont drive 100 miles every day....so far they are quite grippy and I suer have pushed them around and they handle perfectly....not sure how they will fair out after a couple of thousand miles on em...
Javvy
Old 05-02-2014, 06:00 PM
Maini Maini is offline
Mein Auto: 2010 BMW 535xi
My original Goodyear RSA laster 45K miles. I have a AWD car and I rotate and balance tires every 6K miles for free at America's tire or Discount Tire.
Since this is a AWD car my set up is all wheels and tires exact same set up (not staggered). My tires last because I rotate them and that is recommended.
Why does BMW have staggered set up?? what is the real advantage?? I see that on Mercs too.. but Toyota, lexus, Acura, Nissan infiniti all have straight set ups.. why the difference??
2010 535i xDrive AUTO
PDC, NAV, HUD, HD & SAT Radio, Premium Audio
Premium, Sport & Value Packages
Black Sapphire Metallic
Black Dakota Leather
