Can I fix this gap myself? - Bimmerfest - BMW Forums
Old 09-19-2012, 03:41 PM
teklord69 teklord69 is offline
Mein Auto: 2001 330ci 5-Spd
Is it easy?
Old 09-19-2012, 04:06 PM
senser senser is offline
Mein Auto: 540i/6 E39
Try fixing it and tell us.
Old 09-19-2012, 04:10 PM
ahspao ahspao is offline
Mein Auto: 2012 535i
I had a similar issue on mine, I think it was caused by the old owner parking over parking stops and yanking back on the bumper when reversing out of them. The bumper slides onto some plastic mounts that hold it in place and mine ended up being cracked which caused that same sagging in the same spot, I took it into a shop and the guy said he can either fix it or bootleg it...being hard pressed to spend money on cosmetic fixes at the time I told him to bootleg it. He removed the trim strip that goes one the bumper and put a pair of drywall screws right through the bumper and put the trim strip back on. Has held for over a year, but I don't know how viable of a fix that is....just wanted to give you my experience.
Old 09-19-2012, 04:18 PM
Tuskfish Tuskfish is offline
Mein Auto: 2001 530iA Sport
Sure - provided the hanger tab is not broken it's an easy fix. Pull the wheel and inner fender / splash guards and slide the bumper cover back on the hangers.
Old 09-19-2012, 04:24 PM
bkgreene39's Avatar
bkgreene39 bkgreene39 is offline
Mein Auto: 1998 BMW 528i
Maybe this will be of assistance.
http://forum.roadfly.com/threads/131...r-with-photos-
Old 09-20-2012, 08:23 PM
Originally Posted by bkgreene39 View Post
That helps a lot.. Thanks!
Old 09-19-2012, 04:35 PM
Dking078's Avatar
Dking078 Dking078 is offline
Member Supremo
Mein Auto: 2003 BMW 540i
Totally fixable (Assuming you tabs arn't broken!).. Just take off the bumper and adjust the holding tab. The tab is secured by 2 screws and they can be loosed to move the holding tab accordingly, I had the same problem on mine.
2003 BMW 540i [Sterling Gray / Gray]
[Msport] [Mods from A-Z] [Two-Tone Interior]
The one stop trim shop See the Dking Difference [Click]
Stuff For Sale: PM for info
1 Set of E39 OEM Maplewood Trim $220 Shipped
1 Set of High Polished black E39 OEM Trim $275 Shipped
4 E39 OEM Headlight Ballasts $58 Shipped each
E38 Illuminated Interior Door handle set $72 Shipped
Old 09-20-2012, 03:50 PM
energizedmortal's Avatar
energizedmortal energizedmortal is offline
Mein Auto: 2003 530i
I used tie zips to fix mine
