M54 Engine Oil Leak
Guys, I have M54 engine in my E60 and it has a leak which is very annoying since I am loosing 500ml about every 2-3 weeks. Here are some pictures of where I can see the oil.
1. First - There is oil getting accumulated in a puddle around the 1st and 2nd spark plug start from driver side. 2. Second - There few drops of oil between wiping it clean around 4pm and 12pm next day morning. The picture is of the bottom front left corner straight under the vanos areas. 3. Third - there is slight leak under the cover of vanos, but also the two electrical connector on the left of vanos appear to be leaking oil. Can this oil leak slip down to the second pic. Which part is leaking that I need to fix is what I need to know considering the pictures. Is it the cylinder head gasket that is gone? Or something else. Any suggestions are welcome. |
Sounds like it`s time to replace the CVV.
(VCG and new plugs should be done at the same time)
(R.I.P. Jever) *Please support the Wounded Warrior Project* |
If a new set of valve cover gaskets doesn't stop oil from seeping to the top of the valve cover, then the valve cover is likely warped and will need to be replaced.
![]() E36 DIYs: Air Pump | Vent Gauge | E46 Armrest | SmarTire TPMS E46 DIYs: Hella TPMS | Aftermarket Horns | Window Regulator Notes | Trunk Wire Harness | Trunk 12V Socket |
Change the valve if you never have, along with the two vent hoses and the drain hose that goes down to the oil dipstick tube. Then change your leaking gaskets caused by this failure-which can also blow you OFHG, and/or oil pan gasket. The weakest link - usually VCG- is going to blow when CVV is inop. |
Any help would be appreciated! Thanks! Alan |
http://forum.e46fanatics.com/showthread.php?t=643639
"If everything seems under control, you're just not going fast enough" -Mario Andretti. ___________________ River City Bimmers Chapter 2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta. 1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black. Last edited by X3-terrestrial; 10-03-2012 at 11:30 AM. |
Looks like the leak I had in my m54 a fee weeks ago. The valve cover gasket was dry and brittle. A new one fixed the problem.
Thanks Guys, will let you know how it went.
Also, I read that with VCG, one should change the spark plugs. The spark plugs were changed 36K's before on 100K service and it is sitting on 136K's. Should I change the spark plugs? What is the lifetime on BMW spark plugs? Is there any specifications on spark plugs? BMW or OEM? (I know this is debatable, but just share your experience here guys) Last edited by kskane; 09-23-2012 at 01:59 AM. |
Boys, I need some help. While I was about to bolt the new gasket in, I !@#$#@#@!@#$ the first screw on torque.
WHAT torque do the bolts on valve cover gasket needs to be? I read somewhere 7ft-pound and I was bolting it to to 7, but cracked/ripped the nut from engine assembly (don't you laugh at it ). Much to my luck, that screw on the engine is not part of the engine (now I will have to ask the $stealer for replacement and car is going to be out of action for few days). So please help with torque values. Also, while I was changing the gasket (still am with the car in garage and engine open with missing bolt), I checked the spark plugs and they are NGK. I have attached picture of contact points. Do you think I should change it? |
If the valve cover gasket was previously replaced, it's possible that whoever did the work overtorqued and weakened the studs in the cylinder head. Fortunately, replacements aren't expensive. Also, remember that a torque wrench is most accurate in the middle of its range, and it is least accurate at the limits of its range. A 5 to 45 ft-lbs range, for example, isn't the best choice.
Part number 07 14 6 958 587 Otherwise, for M7 bolt, would I need a 7mm helicoil or a 8mm helicoil. Also, what is the thread size on the bolt M6/7x29.5 bolt, 1mm or 1.?? mm or 0.?? mm For further details, the bolt with part number: 11121718856 is going into the engine assembly and is free i.e. the thread on the female part which is in the engine assembly needs repairing for which I need helicoils. But what size of helicoil is what I need to know. Last edited by kskane; 09-27-2012 at 10:02 PM. |
Cool, thanks. Everything went well!
"If everything seems under control, you're just not going fast enough" -Mario Andretti. ___________________ River City Bimmers Chapter 2005 X3 3.0i ZPP, Htd seats, Htd strng, Black Sapphire on Terracotta. 1995 ///M3 Coupe, Lux, MT, Htd seats, Cosmos Black on Black. |
kskane did you only change your valve cover gasket? or did you also change your cvv? i have the same exact problem. my pictures even match your first two in the first post. i had the valve cover gasket replaced less then twenty thousand miles ago. and was just about to change the cvv, but was curious if maybe its more so the gasket. was going to still change the cvv but would rather knock two birds with one stone.
for sure i am i was just wondering if i will need to re replace the vcg it was replaced recently, but was wondering if the cvv just being replaced would stop the extra pressure causing the leak. i dont mind if i have to re replace the vcg i just didnt know how fast it would take for that to fail because i stopped driving the car once i had the slightest sign of it acting strange. just didnt want to replace the cvv, and not redue the vcg and that cause it to still be at fault. you know? i say this because i know me and my friend change the vcg and vanos rebuild less then twenty k ago.
