Old 09-22-2012, 06:55 AM
HANSONCLN HANSONCLN is offline
Mein Auto: 99 m Roadster
M Roadser oil change
So the question is Oil filter first then oil or vise versa
Old 09-22-2012, 07:33 AM
Dave 330i's Avatar
Dave 330i Dave 330i is offline
The King of Common Sense
Mein Auto:
I've seen it done both ways in changing the oil in BMWs. Guru Kris L replaces the oil before changing out the filter. I change the filter as the oil is being drained out thus saving time. The whole affair takes me 15 minutes, while those who use an oil extractor takes much longer, enough time for a few beers as you can see in his video.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein
Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton.
Old 09-22-2012, 08:44 AM
Randy Forbes's Avatar
Randy Forbes Randy Forbes is offline
Investigative Tinkerer
Mein Auto: ///Motorized Vehicles
The (old) oil will remain in the filter until the vacuum is broken, by loosening the lid. If you drained/refilled the crankcase, then loosened and changed the filter, you would've introduced the dirty oil into the fresh oil.
I loosen the filter as the very first thing, allowing it to drain into the crankcase, then simultaneously evacuating the crankcase by siphoning the oil out.
Upon refilling, I like to pour at least a quart/litre of oil into the filter housing, then fit the filter and continue pouring oil over it. This saturates the filter, reducing the amount of time it takes for the engine to acheive oil pressure.
Randy Forbes
1957 Austin-Healey 100/6 Wine Red
1961 McCulloch R1 go-kart Screaming Yellow
1999///M Rdstr Cosmos Black Eurosport Twinscrew S/C
1999///M Coupe Estoril Blue Eurosport Twinscrew S/C
2001///M Rdstr Steel Gray
2011 X5 35i Sport Deep Sea Blue/Cinnamon
Old 09-23-2012, 04:19 AM
Pinecone's Avatar
Pinecone Pinecone is offline
M Mad
Mein Auto: M Roadster/M3
As Randy says, if you want to keep about 1 quart of dirty oil in your engine, change the oil first, then the filter. I prefer to remove most of the dirty oil.
I start the extractor, change the filter, then refill the oil. Multitasking.
Since any oil you pour into the filter housing, drains into the crankcase as you are putting the cover back on, I don't bother.
Terry Carraway
'95 Alpine M3 LTW
'00 Dakar M Roadster
'02 Topaz M3
