E36 (1991 - 1999)
Old 09-23-2012, 04:25 AM
70simple 70simple is offline
Mein Auto: E36 318Ti Sport
98' 318Ti Gearbox Problems
Help Please!!! .....my 98' E36 318Ti recently got stuck in 3rd gear (manual) & was told by my local mechanic it required a replacement gearbox. After being quoted around £400 odd to have it replaced, a mechanic friend suggested that we could do it ourselves.
After through research & being told that the manual gearbox was common across all the engine sizes & models in the E36 range, I plumbed for a low mileage box from a 96' 325, from a car breaker. Upon fitting we have discovered that the selector is shorter on the replacement gearbox, than the one taken off the broken gearbox & that the old one won't fit either.... The gear shift keeps hitting the top of the centre console or doesn't go into gear at all!!!!!
Can someone please enlighten me as to whether the transmission tunnel or gearbox on the Compact is different from the other E36's in the range or whether there is a difference from the 96' to 98' models?????
Old 09-23-2012, 08:03 AM
AndrewZ's Avatar
AndrewZ AndrewZ is offline
a broke down melody
Mein Auto: It has two dipsticks
Welcome, I moved your thread to the E36 forum!
Old 09-23-2012, 09:10 AM
southpark11235's Avatar
southpark11235 southpark11235 is offline
Mein Auto: 1999 BMW 323is
Have you tried turning the shifter around. After I replaced some bushing in my shifter I reinstalled the shifter backwards and got a similar problem. http://www.bimmerfest.com/forums/sho...hlight=shifter
Alex//1999 323is - power e46 m3 seats, style 43 rims, 328 exhaust
For sale black e46 interior parts
“Dude, dolphins are intelligent and friendly!” — Wendy
“Intelligent and friendly on rye bread, with some mayonaise.” — Cartman
Old 09-23-2012, 10:30 AM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
It isn't correct to say that the manual transmissions are exactly the same across the entire line, because they don't in all cases. With that said, the 318 and 325 do use the same transmission, so you should be fine on that level. You should be able to swap your old linkage onto the donor transmission. There are no differences in the trans tunnel or anything along those lines either.
1998 BMW 328is
1966 Pontiac GTO
