Cracked oil pan - Bimmerfest - BMW Forums
Old 09-26-2012, 12:55 AM
Bigrob52 Bigrob52 is offline
Mein Auto: 05 645CI
Unhappy Cracked oil pan
I took my 05 650 in for a oil change and was told that they couldnt do it because the oil pan was cracked and would have to be replaced for a mere $750.00????? need to find another shop? I went to the dealer since i stil had free oil changes but i knew it was to good to last??/ has another one else had this problem??? How much did it coast to get repaired????
Old 09-26-2012, 04:59 AM
Mulchman's Avatar
Mulchman Mulchman is offline
Mein Auto: '07 650i
01 Oil Pan 1 11137574532 $222.76
The pan is $222 from RealOEM.com, but that price does not include new oil, oil filter, gaskets and o-rings etc... So figure about $350 or so for parts. $400 in labor is not that bad (at a BMW dealer) as the job does take some time. An indy mechanic would be able to shave the labor cost by $100 or $200.
I've never looked at my oil pan to see how difficult it is to get at but, I pulled one off my Saab and it was an easy job. If you do any of your own work, you ciould do this for the price of parts.
Good luck.
M6 bumpers, skirts & wheels
HUD, Comfort Access
Old 09-26-2012, 07:25 AM
pablo645's Avatar
pablo645 pablo645 is offline
Mein Auto: 650i Convertible
To do the oil pan is not a difficult task if you have the time and handy with tools. Since this is not your transmission pan that is cracked, the engine oil is relatively cheap compared to the transmission oil. I am assuming that it's the lower pan that is cracked and if that is the case you could do it or find a reasonable indy shop. All the parts should run you arond the price as indicated by Mulchman but the labor should run you cheaper than what the dealer is charging. Personally I believe a job like this should run you about $500.
2012 650-xDrive Convertible. Titanium Silver Metallic - M Package - Driver assist package- Cold weather package - luxury seating package - Bang & Oulfsen system.
Previous Cars:
2008 650 Convertible 6 speed manual
2004 645 Convertible 6 speed manual
1994 540 6 speed manual
Old 09-26-2012, 09:55 PM
Yorgi's Avatar
Yorgi Yorgi is offline
Oil pan is very simple so I would find an indie to install it. The part is $219 at Tischer, the gasket is $17. You are supposed to change the 20 bolts @ $0.80 each and the o-ring on the oil level sensor @ $3.
The oil change and filter is another $90 in parts, but you were going to do that anyway.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
