Old 09-26-2012, 09:46 AM
jsaklas jsaklas is offline
Mein Auto: 323i
Power Steering hoses - which is pressure hose
I need some advice, and help. I have a 2000 323i. I took it to a reputable mechanic who identified several problems, one of which was that my "power steering suction and return hoses" are leaking. I have several questions:
1. Which hoses in the attached diagram are the "power steering suction and return hoses?"
2. I am a novice. Is this ps hose job doable by a novice?
3. Is there a good video to help?
js
Old 09-26-2012, 10:04 AM
G. P. Burdell's Avatar
G. P. Burdell G. P. Burdell is offline
Rambling Wreck
Mein Auto: E46
The pressure hose has the long, U-shaped loop that extends below the steering rack.
Consider replacing all of the hoses and the power steering fluid reservoir while you're at it.
Old 09-26-2012, 10:45 AM
hexy27's Avatar
hexy27 hexy27 is offline
GO FLYERS!!!
Mein Auto: 2002 330i
^^^^^^Agree with the above......hoses #7 and #11 are notorious for leaking and are not all that expensive. Keeping the fluid from dripping into your alternator will save you in the long run as well.
Old 09-26-2012, 10:49 AM
hexy27's Avatar
GO FLYERS!!!
#10 is the cooling line that runs behind the radiator...the pressure hose is #3. If you plan to change the lines I mention above be sure to get the quick disconnect tool as well.
http://www.amazon.com/Assenmacher-AS...isconnect+tool
Old 09-26-2012, 11:22 AM
Germane Riposte's Avatar
Germane Riposte Germane Riposte is offline
Go Hokies!
Mein Auto: 2001 325i Touring 5-speed
+1 on getting the disconnect tool - makes it easy peasy to remove the #7 & 11 lines hooking to the #10 cooler (which you shouldn't need to replace). Check out Starless's DIY in the Wiki to see if the overall job is something you'd like to tackle.
I replaced all four lines (#1, 3, 7 & 11) & the reservoir. Aside from the pressure line, they're not terribly expensive. Don't forget washers & hose clamps.
Make sure you get the correct #3 pressure hose, for either the LF-20 or the LF-30 pump. Going just by the car's manufacture date isn't wise, as an LF-20 could have been replaced by an LF-30. To be sure, take a look at the pump pictures on Pelican Parts (or another vendor) - they're quite different.
Old 10-03-2012, 11:07 AM
Mein Auto: 323i
I finally have a little time today to check things out. I took off the air box to get a better look-see. It is hard to tell what is leaking, all the hoses are covered with at least some oil/grease and crud. I decided to replace all the hoses and the reservoir (I assume my daughter never did - so the filter is probably all mucked up.) as well.
Now for the dumb question. I have the hose tool, but it is not clear to me how it works. Can someone help?
js
Old 09-26-2012, 10:43 AM
Mein Auto: 323i
G. P.,
Thanks, and to confirm, in my mechanic's statement, ''power steering suction and return hoses" the suction hose is the pressure hose? Furthermore, is this the #10 hose in the diagram? Also, do you think a novice could do it?
I will get under the car tomorrow to get an impression on whether I could do this or not.
js
