E30 (1982 - 1993)
God's Chariot. The E30 was produced primarily from 1982 through 1991. The cabriolet was the one exception which was produced through 1993. |
Rear wheel bearings!$@&$)
Rear driver side wheel bearing went bad so I decided to replace both sides. Passenger side came out no problem and went in the same. The drivers side on the other hand is a not playing so nice. I pulled the center out of it while trying to pull it out, so now I have the outer casing stuck in there. Other then cutting it out you guys have any tips?
dry ice in there, you can also buy it in a can as a spray.
Brilliant, I tried using a torch on the outside but with no success
Cut it with a Dremmel.
Good - Fast - Cheap: Pick any two. Current: E23 735i; E30 318i; E32 735iL; E38 735iL; R50 Cooper; R55 Cooper Clubman. Previous: E21 318i; E32 735iL; E34 535i; E38 730iL; E53 4.4i
I use butane, it acts like liquid nitrogen just not as extreme and can shrink those races a good bit, enough to tap them out easily.
Takes a full can though and helps to do it on a day over 80*.
To get mine out I used a hand operated hydraulic gear puller (pusher). Worked very well. Maybe you could hire one? Brand i have is 'Sykes Picavant'
