E30 (1982 - 1993)
Old 09-30-2012, 09:50 PM
Hoser121 Hoser121 is offline
Mein Auto: 325E
Question 325e with no Sparky
So i got this 1986 325e given to me by my neighbour. He says it ran fine for years but they parked it one time for six months and then it wouldn't start,it cranks fine. I did some poking around and found that the coil is not making spark...it has power but obviously the ground circuit that controls the spark is not doing it's job because when i apply a ground to the coil manually and then remove it .....it makes spark.
Question: Is the ECU the only thing that controls the ground to the coil or is there another relay? My Haines wiring diagram isn't very good but it does show a "Speed Control Relay" as part of the timing circuit .....where is this relay?
Also, this model has two Crankshaft sensors located on the bellhousing whose resistance i have checked and found to be 1050 Ohms on both and infinite to ground. I have been trying to take them out to have a look at and maybe even replace but I`m having a bugger of a time getting them out. Remove allen key and pull...right??.....wrong!! They're pretty stuck.
Any help would be appreciated.
Old 10-01-2012, 09:39 AM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
You missed a couple of steps:
Soak the screw and sensor body with penetrating fluid (like PB Blaster, Kroil, etc.)
Wait for as long as you can stand it, but at minimum, an hour.
Remove Allen screw
Spray with more penetrating fluid
Wait some more
When you finally feel lucky, carefully grip the sensor top and try to gently twist it
If/when it breaks free, remove it
Good luck.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
Old 10-07-2012, 07:22 PM
BMWFatherFigure's Avatar
Old School
If the sensors test good (which they seem to) I would not worry about removal. I would start checking relays and fuses. Get a spark the go for fuel system if it does not start.
Current:
E38 Parts Car
Previous:
