Old 10-01-2012, 06:19 AM
panxiaoyan panxiaoyan is offline
Mein Auto: 2008 x5
Angel eye
Can some one please give some guidance where I can get a good h8 led bulb for my angel eye . My x5 got the dull yellow angel eye . Would like to upgrade it to a good one . Year 2007 model . Thank you
Old 10-22-2012, 04:32 AM
brown370 brown370 is offline
Big Mike Brown
Send a message via AIM to brown370
Mein Auto: 07 BMW X5 4.8i
Check for H8 bulbs on eBay. Make sure you get high power bulbs. If you use the daytime running light feature.
11 Audi A5 2.0T 8 Spd Tripotronic w Sport Pkg, 19" Anthracite Wheels
12 VW CC 2.0T [/B] stock
05 VW GTI 1.8 T 5 Spd, Coilovers, Big Brakes,
(Previous rides)
04 BMW 645 CiC Auto
97 VW Jetta Jazz 5 SPD
06 Mazda 6 Grand Sport Auto
05 BMW X5 3.0 6 SPD
05 Infiniti G35 6 SPD
04 Volvo S60 "R" 6 SPD
99 Nissan Maxima 5 SPD
91 Nissan 300ZX 5 SPD
92 Honda Prelude Si Auto
76 Fiat Spyder 124 5 SPD
Old 10-22-2012, 11:38 AM
kobe1292 kobe1292 is offline
Mein Auto: 2010 BMW X5 30i
I saw lots of people in this forum use LUX Angel Eyes and it has pretty good feedback, but seems like it's only fit E70 with HID, does ur car have factory Xenon?
Old 10-22-2012, 11:52 AM
kungpao kungpao is offline
d is for Diesel
Mein Auto: 2009 X5 35D
yeah I was thinking of doing this too. I bought a pair of white LED license plate lights from an ebayer and they were uber bright! He's got angel eye bulbs too so i was going to go that route.
Question is... once the halos are "upgraded" that means a headlight temp change needs to be done too right?
Edit:here's the guy I bought my lp lights from http://stores.ebay.com/TT-Motoring/_..._sid=189037579
-kp!
2009 X5 35D
Old 10-22-2012, 04:46 PM
ChuckGr ChuckGr is offline
Mein Auto: X5 35D
kungpao,
Let us know how the halos you get work out. TT-Motoring has great prices.
Chuck
Old 10-22-2012, 07:20 PM
JohnMN JohnMN is offline
Mein Auto: X5 35d, S4, V50 T5
Just ordered these. Will post with results.
http://www.highperformancebulbs.com/ne20wacrledh.html
Old 10-25-2012, 04:47 PM
John, let me know the result and how hard to install them, I live in MN too
Old 10-25-2012, 08:05 PM
I'm in Edina if you'd like to see how they perform or need help with installation if you purchase some.
Mine are installed! I ordered them on the 22nd with 5-7 day ground shipping. Received them on the 24th. Great turn around.
They came in a simple black box with some contact information and a packing slip inside, but no instructions. They indicated that instructions can be found online. Instead, I referred to the vehicle owner's manual on bulb replacement on page 270.
Twist and remove a cover, twist and remove the existing bulb, and disconnect the electrical connector. Insert and twist the LED bulb, connect the connector, and stuff the wire and power modules into the headlamp housing. Insert and twist the cover. 15 minutes per side if it's your first time.
They work great and have no codes so far.
First impressions are that they are brighter than the stock halogens. They're not as bright as factory LED angel eyes, which is fine with me as I think stock LEDs are too bright.
I haven't seen them in direct sunlight yet. However, with cloudy skies and at night I think they look great!
I purchased these (over other brands) because they had good feedback and they actually stated their power level (20W). I also liked that they dim similar to the halogens when turned on and off.
Here are a couple of pictures that I tried to expose to reflect how they appear at night. In taking pictures I realized how hard it is to capture how they really look.
Old 11-04-2012, 07:59 AM
macming macming is offline
Mein Auto: E46 M3, 2011 X5 35i
Looks great! I just paid for a set of these as well. Are you still happy with your choice?
Old 11-20-2012, 07:35 AM
smyles smyles is offline
Mein Auto: X5
I purchased these (over other brands) because they had good feedback and they actually stated their power level (20W)...
Most likely these are 4 regular 5W LEDs, hence their 20W claim. Considering the design of the pre-LCI rings and the directional nature of the LEDs output, two of the LEDs are pretty much useless, so in the end these aren't much better than "2 LED 10W" sets.
I bet on a sunny day the outside rings aren't lit at all.
Old 11-20-2012, 08:36 AM
d is for Diesel
Originally Posted by ChuckGr View Post
kungpao,
Chuck
Oops. forgot about this.
I didn't buy the TT-Motoring ones for my e70. Wound up buying these instead. Overall, I'm pleased with the look. No error messages. The pins didn't quite fit. I had to reach in there with a needlenose and squeeze the prongs together for them to be able to plug into the female end in the car. I'll post pictures when i get home. I took pics with one side in and the other stock for comparison. Overcast daylight pictures.
-kp!
2009 X5 35D
Old 11-19-2012, 08:47 PM
Joecam Joecam is offline
Mein Auto: 2009 X5
Angel Eye Bulbs
I've tons of research on this subject and the best and brightest bulbs are from Ijdmytoy. They just came out with new Cree 20 watt bulbs. I just ordered them myself.
Old 11-21-2012, 04:45 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
Are these hids?
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
Old 11-22-2012, 05:33 AM
Mein Auto: X5
Originally Posted by Joecam View Post
...replacing the fog lights with LED...
Don't do it unless you want to turn fog lights into pure cosmetic item. LEDs don't provide the same output, white light is useless in fog, you'll have to use coding to get rid of error messages, they'll flicker, no cornering function, etc etc.
And for the love of god don't install xenons either, unless you want to be king of *********s.
