E60 (2004 - 2010)
BMW 5-Series (E60 chassis) was first seen in the Unites States in the fall of 2003 with a 2004 Model Year designation. The E60 is now available as a 528i, 528xi, 535i, 535xi, 550i and a 535xi sports wagon! -- View the E60 Wiki |
Headlight, Xenon bulb replacement
Just replaced a burned out headlight xenon bulb.
BMW wanted almost $400 to replace it ($240 for part, plus $130 for an hour of labor, plus tax). Instead I went for Option B and bought the bulb for $40 on ebay. The oem bulb is an Osram D1S with 4150k brightness. I bought a DOT stamped Philips XenStart D1S Xenon from oemxenonparts, 4300k, and it matches perfectly with the Osram. No need to replace both. Installation required removing 2 top screws and 2 at the bottom, you need an extension to reach down. The headlight unit then slides forward and you wriggle it loose and tilt out of the cavity. A plastic cover on the back drops down to expose the bulb. turn it 1/4 turn and remove. Unplug the wire, take off the neckless type bracket, like a collar, and clip onto new bulb. Install. Whole procedure took 20-30 minutes but this was a first time experience and I was figuring it out on the fly. The 2 lower screws are tricky to refasten. You need an 8mm socket with magnet at bottom to hold the screw, or a nut driver with long shaft, 6 inches or so. I stuffed a little duct tape inside to make it sticky. Did the job.
Styling: M5 body kit, M5 trunk spoiler, LED Angel Eyes, HID fogs, LED side markers, Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Zapco Z8 DSP, Zapco Z-150.6 amp, iDock on dash Performance: JB4/G5 ISO flashed on Cobb, Meth Injection, AR Downpipes, ER FMIC and Charge Pipe, DCI, Walbro LPFP, RB turbos. H&R Sport springs/Koni FSD shocks. |
Oceans, just wanted to know why you did not go with 6000K which is safe and many people have been using it already..
Jet Black | LCSW | DP WT | ZCW | ZPP | ZSP | 261 | 2TB | 322 | 415 | 416 | 609 | 610 | 620 | 677 | 6FL | 6UH |Front/Rear Cameras | Escort 9500ix | Performance-Cobb Stg2+FMIC ST Agg | Injen Intake | BMS OCC | ER anodized FMIC |AR DP Catted |TIAL Q BOV | ER Charge pipe | Spacers (F 12mm/ R 18mm) Cosmetic-32w Cree LED AE | Xenon HID Fog Bulbs | M5 trunk & Roof spoiler rear | XENON white Emblem LED BG Light | LED Side Marker | M5 bumper | Hamann LP | License & Interior LED lights| Tinted glass | |
I wanted to color match it to the stock bulb. Only replaced one, not the pair.
Got it.. Cool..
How long did your first bulb stay?
Hey I just PM'd you back, sorry for the lag. Glad to see you go it figured out. Those damn bottom screws can be a pain if they drop into the bumper which I've done before.
2009 AW 535i -Sport, Premium Package, and Comfort Access -20" Forgestar F14 Black Gloss, Cobb PTF E30 map, KW V2 CO's, Remus Sport Exhaust, BMS DCI, RPI Scoop, Full Front 3M PPF, 35% tint all-around, Orion V4's, Bruce v6.1L cables, LED interior lights, WeissLicht License Plate LED, Trinity Smoked LED side markers, Bimmian Smoked Reflectors, OEM black gloss grills, and Invisibulb turn bulbs. |
+1 on that!
Sent from my MB855 using Bimmer App |
For future reference, just loosen the bottom bolts as the brackets on my 2007 530i are slotted, hence bottom bolts did not need to be removed. Also, top bolts use a #30 torx while bottom bolts use a #20 torx.
