Old 10-02-2012, 10:24 AM
jchamblee jchamblee is offline
Mein Auto: 2006 bmw 330ic zhp
Run Flat Tires
I have a 2013 X5 50i with the M package which has 19" wheels. I do have a spare. I would like any recommendations for a tire that will offer a more comfortable ride and less road noise. The current tires are Bridgestone HP run flats.
Any advice in this matter would be very much appreciated.
PaPa
Old 10-02-2012, 03:02 PM
ard ard is offline
Resident Curmudgeon
Michelin Latitude Run Flats
Old 10-02-2012, 03:19 PM
Thanks for the advice, however I was hoping to get away from run flats.
Old 10-02-2012, 03:48 PM
ard ard is offline
Resident Curmudgeon
Why, are you buying the koolaid that all run flats are the same??
I read people saying "I have the RFTs" as if this is ONE specific tire. There are crappy tires and there are crappy runflats.
If I was going to ditch, I'd gte the mich non-rft.
I have 5 cars, Michelins on all- PS2s, LTX, Latitudes
Old 10-02-2012, 04:01 PM
I know all RFT are different and have different rides etc.. Over the years after having Corvettes and BMWs I have grown tired of the severe thuds on crappy roads caused by RFT's so now that I have a spare tire I am going to change my ride. So for choice of non RFT would it possibly be the Michelin Latitude non RFT?
Thanks!
Old 10-02-2012, 07:08 PM
gresch's Avatar
gresch gresch is offline
Don't be a hammer
Thanks!
I was happy with Michelin PS2 ZP's on my '08 Vette when I replaced the GY F1SC' RFT's , the ride wasn't better, just different, and quieter. But that could have been due to new tires vs old tires regarding noise.
That being said, I'll probably go non-RFT's when the Michelin's on my '12 X5 need replacing.
Old 10-04-2012, 03:23 AM
rashid rashid is offline
Mein Auto: X5 E70, 4.8 - 2010 White
Are you sure about this?
Old 10-06-2012, 10:57 PM
ard ard is offline
Resident Curmudgeon
Originally Posted by ductman View Post
Agreed, first hand experience with that, My E53 X5 which at that time actually came with a full size spare, had a flat, jacked it up, could not for the life of me get the wheel off , afraid
if I pulled on the wheel hard enough , would have come right off the jack, had to call roadside assistance, had to use a rubber mallet to get the wheel off. I carried a rubber mallet from that point forward.
Kick it. Put you back to the wheel, sharp kick with the back of your heel.
100% certain that that is my opinion
Old 10-07-2012, 03:14 PM
jerryjash jerryjash is offline
Mein Auto: jetta tdi
tires
I have been very happy with Vredestein Tires on my 2012 X5 ... Quiet .Ride... Handling is second to none...13000 miles and very little wear.. I will buy another set ...
Old 10-07-2012, 05:00 PM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Which Vredesteins and in what size?
Old 10-02-2012, 03:35 PM
Mrt0006 Mrt0006 is offline
Mein Auto: 2007 X5 3.0
If you want to stick with run flats, try the Michelin Latitude RFT's. I had two sets of those on my 19's and liked them a lot. IMO, for comfort and road noise, its a lot better than the Bridgestone's RFT's. But if you're open to non-RFT's, there are a lot of options (search this forum and you'll see a lot of member suggestions). I currently have Continental CrossContact UHP (non-RFT) for almost a year now and Im happy with this set.
Old 10-02-2012, 03:40 PM
Could you tell a big difference between the RFT's and the nonRFT's, particularly in ride comfort?
Thanks a bunch!
Old 10-02-2012, 04:11 PM
Thanks a bunch!
Between the Michelin RFT and Continental non-RFT, the road noise is almost the same for me. They're both quiet. In terms of ride comfort, I'll pick the Continental between the two. Havent had a chance to try Latitude non-RFT, so I cant give any hands on comparison between Mich and Conti non-RFT.
Old 10-02-2012, 04:24 PM
ccieurzo ccieurzo is offline
Mein Auto: 2013 328i M Sport
Consider the Continental Extreme Contact DWS as well. Great wet performance and very good in the dry as well. Surprisingly good snow performance for an A/S tire, though that is probably less important to you.
Chris
2013 328i MSport
2012 X5 50i (returned due to PCS move)
2003 K1200RS
2008 M5 (traded for X5)
2004 330ix (former winter beater)
2003 M5 (traded with 103k, still working fine)
Old 12-03-2012, 05:30 PM
clinkinfo clinkinfo is offline
Mein Auto: x3,x5
So far my short experience with the DWS has been great too. Excellent ride quality, much softer on those thumps your referring too (I have a covertte too, I know the run flat thump you're sick of). Once I changed over I was amazed how much better I felt the ride was on the X5.
Another odd thing I can't explain well, the run flats in the staggered 20 inch setup loved to fall into the highway grooves made by the heavy trucks around here. It almost felt like you were fighting the car from drifting in and out of the indentations on each side of the lane. The wide tires of the corvette do the same thing, so I never thought much of it. However, After switching to the DWS, the car doesn't fall into those groves the same way. I can pleasantly and loosely hold the steering wheel and not fight it from drifting left and right, in and out of the road indentations. I didn't expect that difference in the switch but it's oddly noticeable.
Old 12-06-2012, 06:56 AM
emh1960 emh1960 is offline
Mein Auto: 2011 x5
Replacing mine today
I have the original bridgestone dueler hl tires on my car. I've put a lot of highway miles on my car. I bought it new in 9/2010 and got 52k out of them, even passed inspection with them 2 months ago. Drove over a curb last night, tire pressure light came on and the right front tire looked low. I then continued to drive approximately 30 miles at 35-40 mph till I got home. Did some research and decided to stay with the run flats. This is my first BMW and it just occurred to me that every other new car I have bought was delivered with terrible tires that lasted barely 15K miles. So I decided to put the exact same tires on the car. Picking it up later today. Spending 270 per tire.
________________
Old 12-06-2012, 05:58 PM
Dano18 Dano18 is offline
Mein Auto: 2012 X5 35d
My car is booked in for next Tuesday to swap out the stock Dunlop SportMax's for Conti DWS.
This is what we did with the first car and we were really pleased with the DWS. Ride better and plenty of grip... More grip in cold wet conditions for sure.
Old 10-02-2012, 05:05 PM
Lance Alot Lance Alot is offline
Mein Auto: 2012 BMW X5 35D
This doesn't answer OP's question (more of an affirmation), but I've decided the Bridestones suck. I have almost 4K miles on mine, and I'm looking forward to replacing them when they get closer to 20k. I purposely got the spare kit when I ordered the car, as I will most likely go non-RFT. Either way, I can guarantee that I won't be getting more of what I have now. They are noisy, unforgiving over rough roads, and tram line much more than I am used to. It's too bad that BMW didn't use a better tire for a generally terrific vehicle.
Old 10-03-2012, 06:43 AM
quackbury's Avatar
quackbury quackbury is offline
///Monkeyazz Duck
Mein Auto: 535i; 428 GC; Twin X1's
Side note (but an important one). It's great that you have the spare, but have you ever tried jacking the X5 up with the factory scissors jack? Do yourself a huge favor and try it this weekend in your driveway. Now imagine doing a tire change with this POS at night, in the rain, on the side of the road. At the VERY minimum you need to carry a 3' by 3' plywood pad. A floor jack would be even better, but who wants to drive around with a missile like that in the back?
Heck, just demounting the wheel can be a challenge when it freezes to the hub. How many of us carry a big enough mallet with us? And jack stands? I would NEVER risk whacking away on a frozen wheel if the X5 was supported by just the factory scissors jack. But how are you going to mount the spare otherwise?
In some respects, RFT's aren't such a bad idea after all.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2014 328i SportWagon
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
2003 540iA M-Technic
Old 10-03-2012, 06:52 AM
Kar Don Kar Don is offline
Mein Auto: '14 & '15 i3, now '16 i3
Well I'd never break the frozen lug bolts with the car in the air... that's just asking for trouble.
2008 Mercedes-Benz CLS550 Iridium Silver/Black Leather -- P2/321/881 (leasetraded 1/10)
2002 BMW 325i --Topaz Blue/Natural Brown Leather --SP/PP/HK/CWP/Bi-xenon (Sold 9/06)
Old 10-03-2012, 07:05 AM
quackbury's Avatar
///Monkeyazz Duck
Missed the point. It's not the frozen lug nuts, but when the center of the wheel freezes to the hub. By definition, the vehicle HAS to be in the air when you do that. And the factory jack is made of limp linguine, so you really should have jack stands in place before you bang on the wheel with your mallet.
If you don't have jack stands and/or don't have a mallet, you are SOL.
Current BMW's:
2016 428 GC MSport
2014 535i MSport
2015 X1 28i xDrive
2015 X1 35i xDrive
Prior BMW's
2011 535ix MSport
2011 X5 35D
2008 ///M3 Vert
2008 X5 3.0
2007 X5 3.0
2006 X5 3.0
2006 550iA SP
Old 10-03-2012, 10:54 AM
ductman's Avatar
ductman ductman is offline
Mein Auto: 2011 X5 35D /2011 M37X
Old 10-07-2012, 04:54 PM
GLJ GLJ is offline
Mein Auto: 11 X-5
Just bought a 11 X-5 it has run flat tires.. Dunlop ...hard riding
Old 10-07-2012, 05:43 PM
335ixGuy 335ixGuy is offline
Mein Auto: Too many to list!
If you have a spare, you can use the spare as the rubber mallet and strike the spare against the frozen wheel. With care of course. But no need to carry the rubber mallet.
Sent from my DROID Pro using Bimmer App
Old 10-07-2012, 09:15 PM
watrob's Avatar
watrob watrob is offline
Mein Auto: X5M 50d
Loosen the studs a little before you jack the car up, rock the car back & fouth tends to break the seal of the rim against the hub.
X5 F15 M50d White, 20"rims, Yellow Calipers, Ceramic Pads. Better off saying what it does not have and that's a B&O Audio System, other than that every option box is ticked.
