E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
Butterfly Valve wide open
I have been experiencing some unpleasant rattling noises at low RPMs after checking out forums etc i narrowed it down to my exhaust butterfly valve not fully opening or closing. I assumed that it was not closing properly and was therefore causing the rattle. I checked it whilst the engine was off and at idle and it is wide open. I thought i was just going to attempt the gold tee/cable tie fix to keep it wide open at low RPMs both solving the rattle and giving a nice exhaust note. However seeing as it is already wide open all the time without any deliberate modifications and the fact that is rattles still, does this mean that i need a new actuator?
So, you look up the tail pipe and butterfly's open & immobile @ idle? You can feel exhaust coming out and sounds loud? Vac line wire tie works wonders, but JB4 does it better in software. |
Correct. It is wide open at idle with exhaust coming out. I was never attempting to get a good exhaust sound i just wanted the low rpm rattle i had to go away. I figured that keeping it all the way open with the vacuum tie method might do the trick but if its already wide open does this mean my actuator is faulty and does not close it at all if it is open at idle and when the engine is off. i have no reason to golf tee/tie the hose off if it doesnt work anyway. Maybe there is only enough vacuum pressure in the hose at certain rpms and that is when i can hear the rattle.
Try a zip tie - a nothing job and then you'll know. I like disabling the flap, but don't find the note very pleasing, vs, say, the sweet sound of a 60's Triumph bike. Othern' that, disabled flap is very good indeed. |
most likely wont cure the rattle though right?
Won't know 'til it's tried - 30 sec to conclusion. OP? |
CALWATERBOY,
In your experience with this mod, any truth to the web populated old wives tale that this open butterfly mod effects low end torque in a negative way? I have searched but have not seen anything that proves or even disproves this affect. |
. Last edited by CALWATERBOY; 10-04-2012 at 02:21 PM. |
I have mine locked open using the JB4, prior to that I unplugged it in the trunk. My butt dyno can't feel any effect one way or another & I don't see any effect on mileage. I just like the sound.
Kevin 2013 BMW 135is 6spd conv - 2011 BMW 335is Coupe JB4/ISO 2010 BMW X3 - 2009 Ford Expedition 4X4 EL - 2009 V-Star 2003 Nissan Xterra 4X4 - 1998 Ford Ranger 4X4 Splash |
Wondering if back press diff, flap closed vs open, had been measured. Direct effect on engine feel & turbo runup. Flap disabled, my ride's closest ever to feel of natural aspiration. Prior, had to put my foot completely flat on the go pedal to get smooth response from a full stop. Forgiving to a degree now. |
I agree it would be nice to see measurements before and after. |
OP, did you ever get to the bottom of this?
My valve also seems to always be open (minus the rattle). I wanted to do the "golf tee mod," but if my valve is already open then why do the mod?
__________________ 2012--E92 335is 2011--E70 X5d 2011--E89 Z435is* 2009--E89 Z435i* 2008--E92 335i [ED 2/23/08]* 2007--MkV GTI* 2006--E90 330i* 2005--E83 X3* 2004--E83 X3* 2003--E46 325Ci* *retired |
The exhaust flap is open at idle even without the golf tee mod. With the windows open you can even hear it close as you start to drive away.
Here is how it works (at least on my car so I'm assuming this is true for other 335's): Without golf tee mod: Idle - open Low RPM's while driving - closed Higher RPM's - open With golf tee mod: Always open |
Might be. I have my tip-in adjusted through the JB4 to a bit softer so that might mask any effect.
