E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
Weird asterisk in dash
Hey guys this morning I got up and it was real cold out, and after I started my car and went a little bit I got this dingy sound and a large asterisk symbol on teh dash. What is that??
Ahhh, the first snow flake sighting of the year. It means that it was less than 38 outside, so be warned of possible black ice. N4S
I'm wondering if the BMW "asterisk" calculates that the temperature is declining when the symbol appears and chime goes off. Last time that I checked, ice doesn't form at 38 deg. F.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
It's a word problem: It takes Franz 7 minutes per wheel to put the chains on his E92. If the temperature is dropping at 0.12 degrees per minute, at what temperature must Franz begin installing chains to get them on the car before the temperature reaches 0°C?
If your sport doesn't put blood, dirt or grease under your fingernails, then it's just a game. Euro Modded|Split Armrest|Rear Foglight Mod|CDV Delete|Shark Fin Antennae Delete|Front Reflector Delete|LUX H8 Angel Eyes|No Bells|Few Whistles|Das Fahren im Freien| BMWCCA#445793
Noted, but my take on Munich's programming of the "asterisk" warning is that it will only appear after a "least squares" calculation of temp...after one hour of numbers crunching (temp calcs)...and only after arriving at an R-squared factor of at least .70. I could be wrong.
Ture, but on a bridge, over pass or in a shady area of the road the air temp may be 38, but the road temp can be below 32. Why did BMW chose 38 as their warning point? Who knows, it ranks up there with run flat tires, not ready for prime time hpfp and the euro beek nose (I actually do know this one) as unknowable BMW quirks. N4S |
Posit a situation where it is a 38 degree night, crystal clear, with no wind. The road is radiating IR in all directions. In most directions, there is an object of similar temperature radiating IR back at it. But, we've said it's a clear night. The road is radiating IR towards the clear sky, but is receiving no IR from the (approx) -450 degree section of interstellar space in the opposing direction. The road loses temperature continually, dropping below the freezing point even though the air around it is several degrees above freezing. The effect is especially pronounced on bridges and overpasses. It's also why you first see frost warnings in the fall on clear nights, but not on cloudy ones. You can do a demonstration with your car's front and rear glass to show the effect. Park the car so that there are branches with leaves above the rear glass, but nothing above the windshield. You will often find that frost or dew will form on the glass exposed to the sky, but not on the glass shaded by the leaves, as they are radiating back at the glass, while the exposed surface has dropped below the dew point / freezing point. The reverse is the case during the day. The air temperature may be below freezing, but the portion of the road looking at the 10,000 degree ball of fusing hydrogen in the sky is raised significantly above freezing. FWIW, George
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion Last edited by Zooks527; 10-05-2012 at 05:20 AM. |
Interesting post...but I've heard that NITROGEN in your tires will protect you from interstellar freezing on bridges. I have at least three good sources.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion |
It's that time of year again....
asterisks, snowflakes, whatevers
Asterisk?
- Tom ------- Mine: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12Hers: 2011 335is Coupe (E92) | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11 BMWCCA #444696 - Click to join and a chance to win a 1-Day M School at the BMW Performance Center!
I think y'all just got punk'd....
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
It's a Moose warning.
'08 335i Sp Pkg, Cobb and wife's '07 X3si San Antonio, TX |
Wrong...that's the "antler" symbol. Everyone in NH, Maine knows that.
Great... Now brace yourselves for a few more Angel Eyes posts.
2008 328xi E90|N51|monaco blue|premium|sports|cold weather|logic 7|ipod|BMW Assist|xenon|sunshade|HD radio |
These lights on the dash are so confusing......
Like this one that keeps coming on: Also a strange clicking that seems to accompany
Laser ___________________________ 2011 535i Black Sapphire Metallic, Sport, Euro Del (ret) 2009 328i Black Sapphire Metallic 2007 Honda S2000 Berlina Black |
My dealer says it's normal, but he was laughing so I'm not sure he was serious. |
anyone else suffering from orange-y glowing mysterious alphanumeric characters (mostly alpha, irrc) that show up in the rear view mirror. they tend to morph into other alphanumeric characters every time the car changes direction. weird.
Odd. I think I need a DIY guide on figuring out how to fix that Rumbling noise when I push the start button. It's definitely strange.
2006 330xi | 6AT | Navi | Premium | Cold Weather |
#25
I always thought that the asterisk lights up on the dash when the AC is on.
