Old 10-03-2012, 06:50 PM
Ironnerd Ironnerd is offline
Mein Auto: 01 525i; '02 530i
Dash dispaly woes...
Hello Forum!!
I have an '02 530i with a high MID. Suddenly two weeks ago, the back light for the odometer, ext. temp gauge and trip mileage indicator stopped working. All other dash and display lights work. Any ideas, I am stumped!
Thanks!
- Ironnerd
Ironnerd
'01 525i
Old 10-04-2012, 11:25 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
Simple. There are five bulbs in the lower part of the cluster. A couple of them are burned out. They are special twist-lock units. Replace them all while you're at it. Get them from the dealer, or a well-regarded supplier.
You'll need to remove the cluster. Search here for the instructions.
Old 10-04-2012, 11:38 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
Click the link below (above the diagram) to get the 11 digit BMW part nbr for item #2...and see the QTY column for the number you need...might as well replace them all if a few have burnt out because they all have been illuminating for the same amount of time...this will prevent having to go back in again if another old bulb burns out.
Q {BMW CCA Member #191509}
(SOLD)
Old 10-13-2012, 11:57 AM
320kplus 320kplus is offline
Mein Auto: 98 e39 540i
Question
Is there a DIY on how to replace these bulbs--I've got a few out myself.
Thanks-
Old 10-13-2012, 06:58 PM
QSilver7's Avatar
Thanks-
If there isn't a DIY in the FAQ thread here...try www.e38.org or www.e38.org/e39 (the 5 & 7 share the same cluster set-ups once they've been removed from the dash).
Try a page search on the sites above [Ctrl+F] and type something like "instrument cluster" or "bulbs" which will skip over non-essential links on the page.
(SOLD)
Old 10-17-2012, 12:32 AM
I simply typed /cluster F3 in the VERY best of E39 Links which pointed me to this, among others:
- How to remove the E39 instrument cluster (1) (2)
