Classic Bimmers
Discussions pertaining to vintage and classic BMW models here... |
733I that has been sitting a while.
Have a 1984 733i that was running fine when I parked it but unfortunately got pushed to the back of my project list. Now after a couple of years I have a new found interest in fixing it up but it will not start. Engine turns over fine but doesnt fire at all. What are some things I should look for and things i should do for a car that has been sitting for a while. Any suggestions are appreciated.
Presuming it has a coil and the 'distributor' on the front of the cam: check for spark. If no spark: check crank position sensors in the bell housing for coil continuity. If they are ok pull off the wire from the ign key to starter and then get a friend to hold the key in the start position (engine will not be cranking). Get under the rear of the car and listen for the one (or poss two fuel) pumps to be running.
Flush the stale petrol (gas) out, replace fuel filter and put 5 gallons in. Then the fun starts....... All the rubber under the bonnet (sorry hood), new battery, check test battery cables, check test alternator, consider tyre replacement - oh the list goes on......................
bimmerfan
