E90/E91/E92/E93 (2006 - 2013)
07 bmw 328i Sedan. NEED HELP!! CC ID CODES
So ever since i dodged a debris that has fallen off someones pick up I have been getting a yellow brake light, yellow triangle, along with some CC ID codes. All i did when i dodge the debris was jerk the steering wheel left and slammed on the brakes. The dash board indicators are the yellow triangle with a circle around it and my parking brake in yellow. When i restart the car the indicators would stay on until i drive for a few mins and it would go away, but only to come back when i make left or right turns. if i was to drive straight or make wide turns, nothing would pop up.
Things that pop up on the dash: Yellow triangle tire pressure brake (looks like this (O) ) The codes are CC ID 24- Dynamic Brake Control Assist Failed CC ID 35- DSC Failed CC ID 50- Run Flat Indicator Failed CC ID 354- Start Assist Inactive I thought it was because i needed to get my brakes changed. so i changed all 4 rotors, pads, and replaced the sensors as well. I also reset all of the brake sensors as well, but the indicators would still pop up again. Any advise on what to do??? |
I have the same issue, I have yet to take it in to get fixed, as I believe it is just a screwy sensor. You probably just jarred the sensor in your steering wheel. At some point I will follow one of the below DIY's and fix it, as the dealership will charge approx 1100$.
This is a known issue: http://www.bimmerfest.com/forums/sho...sc+malfunction http://www.e90post.com/forums/showthread.php?t=520467 Safe travels |
