Old 10-05-2012, 10:24 PM
rafarin003's Avatar
rafarin003 rafarin003 is offline
Mein Auto: BMW 740IL/BMW X5
Water pump issue
My serpentine belt snapped while driving home; I had to have the car towed because I didn't want to risk my cylinder Head. Once at home I noticed the coolant from the radiator was leaking through the water pump and that pump became loose I can sway it side by side. Do I need a new pump and is this a common problem when the serpentine belt of the 740il broke?
Sent from my Galaxy Nexus using Bimmer App
Old 10-06-2012, 01:49 AM
Mein Auto: 1999 740i
YES, your water pump has failed.
Is it common for the belt to break, no. Is it common for the water pump to fail, yes. Mine did the same thing 2 months ago. You need to replace it. About $140 for the pump at NAPA. Another $40 or so for the right coolant from NAPA. Takes about 4-5hrs to change. Not to bad of a job. However, Im guessing your not able to preform this task if your asking this question. Not sure what a shop would charge you. Maybe $500 or so. If you were close to me I would say lets do it the weekend....for a 6 pack. Hope everything works out for you.
Old 10-06-2012, 02:23 AM
rafarin003's Avatar
Water pump issue.
Thx for your prompt reply and the generous offer. And yeah I'm all the way to Palm Beach FL,
I already looked up the pump on ebay, pretty affordable though. I also lined up a BMW mechanic for the job.
Have a nice week-end.
HTML code is Off
