E36 (1991 - 1999)
Old 10-06-2012, 06:35 PM
gregor_lok gregor_lok is offline
GREGOR_lOK BMW 328I COUPE
Send a message via MSN to gregor_lok Send a message via Yahoo to gregor_lok
Mein Auto: BMW 328I COUPE 1996
Exclamation Direction hidraulic
hello friends Bimmers! am with noises in Hidraulic direction, replacing the fluid would improve? a cleaning system in the direction hydraulics would solve? which to the Specification fluid?: Dunno:: Dunno:
Old 10-06-2012, 07:48 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
which hydraulic system?? power steering?? if so, what sort of noise(s) are you experiencing??
also, are these noises more common when the engine is 'cold' (ambient temps) or warmed up (operating temps)??
df
Old 10-06-2012, 08:08 PM
TheDurk TheDurk is offline
Mein Auto: '99 323i Convertible
df
Yeah, he means power steering (direcão hidraulica in Portuguese).
Gregor: Tem esse barulho mais com motor frio ou quando esta em temperatura normal do motor em andamento? E um grito ou um batimento ou o que? Responde em ingles ou portuguese...no segundo caso eu vou traduzir.
O fluido para direção é Dexron III, o mesmo fluido usado em cambio automatico. Ë tambem recomendavel trocar o reservatorio de fluido neste caso por que o filtro do sistema está embutido no reservatorio e tem que ser trocado entero. A peça não é muito cara. Olha esse link:
http://www.dvatp.com/bmw/diy/power_steering_flush/
drivinfaster: I translated your questions--which I would have asked, too, and answered his about the correct fluid (Dexron III) and gave him a link on how to flush. I also told him about the filter in the reservoir and that the whole thing should be changed with the fluid.
I'll keep an eye on this thread and make sure language does not prevent us from helping him out.
Old 10-06-2012, 08:34 PM
he does when the engine is hot. is a noise like "iiiiiiiiiinhoooooooooo" when spin to either side. thanks for the attention and dedication The durrk!!
Old 10-06-2012, 08:35 PM
obridago (that's correct, right??)
knew they spoke portuguese and not spanish, but i don't speak either.
and google translate is not exactly what i would feel confident in using for this sort of translation.
kinda cool, though, to have different languages on board. thank you for your help.
df
edit, sounds like he may be low, which would indicate a leak.
any stiffness in the wheel, or binding then looseness felt?? what color is the fluid?? if dark grey with possibly metalic particles, a new rack and system flush would be in order as this indicates a worn rack.
upgrading to the z3 rack would give a shorter lock to lock ration for a bit more performance.
Old 10-06-2012, 08:47 PM
dc_wright's Avatar
bimmerfest Supporting Member
obridago (that's correct, right??) and google translate is not exactly what i would feel confident in using for this sort of translation.
Este é um tradutor melhor
This is a better translator than Google translate, but it still struggles with technical terms.....
Old 10-06-2012, 09:13 PM
the fluid at this level, this is not leaking, it looks poko this one darker than the photo of the the link you sent me
