Do-It-Yourself H.Q.
Share your DIY projects that have helped you keep your BMW running. For questions about how to fix your BMW use the model specific forums. All BMW DIY tips, tales, and projects discussed inside. Learn to work on your car and know the right BMW parts you will need!
Old 10-08-2012, 10:55 PM
Barry.J.K. Barry.J.K. is offline
Mein Auto: bmw
320d problem
Hi all, I'm barry! I have a BMW E46 320D 2003 & when I drive constant and switch off and shortly after want to start,and the intrument panels come on the heat gage shows in the red and won't start but the car is not overheated as such. Sometimes when I switch the ignition on & off a couple of times the temp gage will show normal in the middle and wil start then.lately its getting worse & the other day was stuck like that for 45 min. Had diagnostics done & when it is like that shows faults like glow plugs, pressure rail and temp at 101 'c but a minute or two later when turning the ignition on & off and comes to normal the diagnostics shows no faults & 86 'c all normal. They told me maybe water pump so I left it by them now they say it might be the computer box which costs an arm & a leg here. I don't know anymore so pls help!
Old 10-08-2012, 10:57 PM
Mein Auto: bmw
Old 10-14-2012, 03:21 PM
Tastylicious34 Tastylicious34 is offline
Mein Auto: BMW 320d
Hi I have all of the same problems as above pls help people are saying it doesn't need glow plugs some say it does heels pls
Old 10-19-2012, 09:21 PM
tator_tot_1991 tator_tot_1991 is offline
Mein Auto: 08 328i
Its def a sensor. These cars are loaded with electronicz
Sent from my DROID BIONIC using Bimmer App
Old 10-19-2012, 09:25 PM
Mein Auto: 08 328i
I had to replace some pc board on mine recently and it no longer throws codes. It was a hub. 1 hub runs separate things in the car. Mine was the SZL $1299. That's with coding and programming
