E90/E91/E92/E93 (2006 - 2013)
Old 10-09-2012, 12:27 PM
Pacifico Pacifico is offline
The right one makes it go
Mein Auto: BMW 335i 2007
Unhappy Repairs Local Guy vs Dealership 07 335i
Has anyone needed their Vanos Solenoid Valve and Mechtronic Sleeve replaced?
I'm looking at a huge cost difference between the dealership and a private local garage that specialized in German autos.
As expected, the dealership would be more expensive, but 3 times as much?
Furthermore, my extended warranty is not all is boasted to be when I purchased it.
If you don't mind please respond with approximate costs of:
Vanos Valves?
Mechatronic Sleeve?
and Oil Filter Gasket?
Please and Thank you.
Old 10-09-2012, 01:21 PM
DSXMachina's Avatar
Automaticallyparsinglinks
I did a job on a 328 last week which the dealer quoted at $2700. Had to do with the intake cam angle sensor and a tune up, and a couple minor things.
I quoted $1200,did it for $1250. Made good money on it too. My customer didn't get a loaner, or a free cup of coffee and a banana, or a car wash, or a multi million dollar waiting area. He did get his car back the same day.
Oh, I used all genuine BMW parts, too.
Old 10-09-2012, 06:36 PM
pointandgo's Avatar
pointandgo pointandgo is online now
bimmerfest Supporting Member
Mein Auto: '11 E90 328i
Note to OP: If you sleep in your car during the cross-country trip, the $1,450 savings might be worth it. Not to mention that you might catch the Fall foliage at its best.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic.
E90 328i
E92 335i 6MT
E46 M3 6MT
E39 528i 5MT
MBz W140 S320
MBz W124 300E (slammed)
(unmentionables in between)
'71 AMC Javelin (4-Spd Stick on the floor)
'67 Pontiac Firebird 'cabrio' (1st car - "the leaker")
Member: BMW CCA
Old 10-10-2012, 06:16 AM
AnotherGeezer's Avatar
Hofmeister Kink
Mein Auto: 2003 530i/5
You can admit it. You had already run out of bananas.
Old 10-10-2012, 05:05 PM
Bemo's Avatar
Bemo Bemo is offline
Mein Auto: 2011 328xi
So when are you going to be moving to Connecticut?
2011 328xi
2011 535xi GT
BMW CCA
Old 10-09-2012, 05:17 PM
aleks001 aleks001 is online now
Aleks
Mein Auto: 2006 BMW 325i
Vanos Valves?
Mechatronic Sleeve?
Vanos solenoids run at about $200 ish each I believe and there are two. Mechatronic Sleeve is cheap, but the transmission pan has to be dropped and the very expensive zf fluid needs to be replaced (About 6.5 Liters) I would say to get all this done even at an indy anything around $1000 would be reasonable.
I would definitely take this job to the specialist, BMW would have a field day on something like this.
Old 10-09-2012, 05:50 PM
Saintor's Avatar
Saintor Saintor is offline
Abuser of everything
Mein Auto: BMW E90 2007
At the end of this DIY; "1. Instead of replacing w/ a new solenoid, try cleaning the solenoid w/ compressed air first."
http://www.e90post.com/forums/showthread.php?t=486201
2007 E90 AW 323i Step | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels & rear 15mm spacers
Old 10-09-2012, 07:07 PM
DSXMachina's Avatar
The BMW tsb requires that before any solenoid is replaced on the warranty, that the tech blow thru it, reinstall it, then see if it works. Yeah, right. A flat rate tech is going to install a questionable part, put everything back together, and chance sending a part which could fail again back onto the road? Not on your life.
At the bottom of the tsb it says "Fix it right the first time, every time!" Except when BMWNA tries to save a few bucks on a part.
