E30 (1982 - 1993)
Old 10-09-2012, 03:10 PM
HicksLJames HicksLJames is offline
Mein Auto: 89 325i
Oil Everywhere!
My E30 has been acting up lately. smoke on startup and terrible idle. i pulled the airbox when i was servicing it and there is oil on my air filter, oil all in the throttle body and everywhere in the airbox. I immediatly thought PCV but i guess there isnt really one just a tube or something going from the crankcase to the intake manifold. Any Ideas?
Old 10-09-2012, 06:14 PM
downhiller's Avatar
livin large
rings. or a cracked block. cracked head. valve guides non existent. either way, getting too much pressure bypassing something when on the power stroke.
Old 10-09-2012, 06:58 PM
Tkaczuk's Avatar
Tkaczuk Tkaczuk is offline
if it wasn't for that...
Mein Auto: M3, & The Wabbit
Did you over fill your oil?
Old 10-09-2012, 07:19 PM
BMWFatherFigure's Avatar
Old School
+ on both above. Which engine?
Current:
E38 Parts Car
Previous:
Old 10-09-2012, 07:55 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
Do you have the 318 M42? Oil level and condition.
Sent from my Nexus 7 using Bimmer App
Old 10-10-2012, 01:22 PM
Mein Auto: 89 325i
It has the M20. I didnt put too much oil in it 4 and a half quarts like always... i did a compression check and a cylinder leakdown test on it yesterday and i didnt see anything that wou;d point to a cracked block or any internal engine damage. im thinking its a crankcase ventilation problem. but im not really sure where to start looking. when i look on AllData all that shows up is a generic drawring of the CCV system.
Old 10-10-2012, 04:42 PM
Old School
If you think CCV problems then first remove all hoses (one at a time so you know where it goes) and check for splits and blockages etc. Replace any thing suspect. Clean out and test any valves. Once you are happy with those results run up to temp and briefly remove the oil filler cap. Check for excessive blow past. Post results and we will see if we can help more.
Current:
E38 Parts Car
Previous:
Old 11-02-2012, 03:24 PM
Mein Auto: 89 325i
so whats up with these hose clamps? should i get the same ones that are on there (the one time use ones) or would i be ok using standard hose clamps. I just dont wanna screw myself if I have to use the same ones already on it...
Old 11-02-2012, 03:53 PM
Tkaczuk's Avatar
Originally Posted by HicksLJames View Post
so whats you can use normal ones up with these hose clamps? should i get the same ones that are on there (the one time use ones) or would i be ok using standard hose clamps. I just dont wanna screw myself if I have to use the same ones already on it...
You can use the normal ones.
