Retrofitting PDC in E60 with OEM BMW parts - Need help with programming/coding - Bimmerfest - BMW Forums
Old 10-10-2012, 09:18 AM
acc41d acc41d is offline
Mein Auto: BMW 520i
Hi there,
I'm going to retrofit PDC in my BMW E60 520i 2003/08 using the following BMW OEM parts:
1 x PDC sensor cable set front bumper
1 x PDC sensor cable set rear bumper
1 x PDC modification cable
4 x PDC sensors front
4 x PDC sensors back
1 x PDC module
1 x PDC / DSC switch console
The retrofitting will be done by a professional who's going to receive a reasonable amount of money from me. But the coding/programming part I want to do myself (since I won't have any money left). I have everything I need to code/program and my laptop set up and running correctly (INPA, EDIBAS, NCS EXPERT, DIS, PROGMAN + USB OBD II cable)
Since I'm a newbie to programming/coding I would really appreciate some help with coding my retrofitted PDC. What do I have to do/code in order to get the OEM PDC working?
Your help is really appreciated!
Thanks.
Old 11-19-2012, 04:29 PM
cforceleritas cforceleritas is offline
Mein Auto: 2010 535i M-Sport
Have you completed any of this? I would be interested to hear how it turned out... I have an E60 and really wish the original owner had ordered this option. I'm tired of pulling up a little too far on parking blocks and would love to retrofit this as well.
2010 535i, Alpine White, M-sport, SAT, Premium, CA, DOB: 23 OCT 2009
Old 11-20-2012, 03:04 AM
Mein Auto: BMW 520i
It's all done and it works like a charm.
Step 1: Install all the parts
Step 2: Update the vehicle order to include PDC ($508)
Step 3: Code the M-ASK (in my case) to show PDC
In total it cost me EUR 490 for the parts and EUR 250 to have it all built in.
For a full overview of all the parts, condition, part numbers and where I bought them see the following website https://docs.google.com/spreadsheet/...4Zkw3MXc#gid=0 (Google Spreadsheet)
If you have any questions feel free to ask them.
- acc41d
Old 11-26-2012, 11:28 AM
Wow, thanks for mentioning the part about updating the Vehicle Order... I have been spending way too much time reading about coding our vehicles!
Anyways, the coding sounds straight-forward enough, but I'm stuck at the center console switch. I can't find the part number for the switch on your spreadsheet (61 91 6938310). I think this was your spreadsheet, I found it on another forum, maybe 5series.net.
What does the switch even look like? Currently on the driver side (left) I have a DSC button, and on the passenger side (right) I have a trunk release button. There are apparently many different combinations depending on if you have heated/cooled seats, active seating, etc.
Check out these images from realoem.com:
I'm just lost because I don't know what the PDC button looks like on a car with the option installed from the factory.
Any help would be appreciated. I am beginning to think a mod like this is above an amateur such as myself.
Old 11-26-2012, 12:15 PM
Mein Auto: BMW 520i
It's probably my Google Spreadsheet.
The switch for my 2003/08 520i looks like this:
If you have a newer model, it might look like the ones on your images but it has to have a PDC switch with the same logo (P with the pawn).
I don't have any seat heating or other fancy stuff, so my center control switch has just two buttons, one for the PDC and one for DTC. If you have other fancy options, like seat heating, you should get a center control switch with the additional buttons.
If you have any other questions don't hesitate to ask them, I'll be glad to help if I can.
- acc41d
Old 11-26-2012, 02:28 PM
txag_530i's Avatar
txag_530i txag_530i is offline
Mein Auto: 2006 530i
Why not just install a video camera from modmynav? It will cost you $485, which I think is about the cost of the PDC controller and sensors. For another $185 you can add a front camera. You don't need to code anything, either.
Old 02-01-2014, 04:46 PM
F-Tar F-Tar is offline
Mein Auto: Alpina B5 -05
How did you solve the signal/gong sound? Did you connect to already existing speaker?
Alpina B5 #001
Old 02-01-2014, 04:49 PM
And where the heck did you get hold of the supply cables? I can only find PDC wiring which i already have.. I need wiring from DSC/PDC panel out to PDC module.
Alpina B5 #001
Old 02-23-2014, 11:34 AM
Retrofit rear done 100% by me, i can provide more details if there is intrest
Alpina B5 #001
Old 03-18-2014, 07:58 AM
BavarianFanatic BavarianFanatic is offline
Mein Auto: BMWs!
I'm looking to do this on my E61N (LCI) with an 9/07 build. I see that there was a retrofit kit for pre-LCI cars that included the bumper harnesses AND a harness for the PDC controller. I can't find anything similar for the LCI cars. Is the car pre-wired? I'm also curious about the switches in the dash. I'm assuming that is handled on the iCan bus? Insights appreciated...
Old 03-19-2014, 04:28 AM
Bought everything from junkyard.. Pick out the cables you need from this big piece. Lenghten the wires to front pcd sensors.
Switch control center, SZM controls buttons. Click image for larger version
Can't tell for lci about pdc button.. But i bought the whole pdc switch control panel.
Pdc module kcan high/low
Connector pdc harness
Some parts (pdc switch control panel not in picture.
What you really have to figure out urself is the button.
Alpina B5 #001
Old 03-19-2014, 06:17 AM
Mein Auto: BMWs!
Switch control center, SZM controls buttons. Attachment 428965
Attachment 428966
Attachment 428967
Attachment 428968
Attachment 428969
So I'm assuming that the connector from the module to the car (not the front and rear harnesses) basically needs power and bus correct? Any idea what the pinouts are? I've been having trouble finding a diagram with that level of detail. My LCI buttons are different than what you've shown, but I'm assuming it's all handled on the bus. They literally have a dozen or so different combinations of switches that incorporate seat heating, PDC, active seats, seat cooling, etc. with either one, two or three physical buttons in each assembly.
I just find it curious that BMW offered a full retrofit kit for pre-LCI cars that included all of the harnesses and the module. It's not longer offered for LCI builds. That's what led me to believe it MIGHT be pre-wired for the module bus/power and the harness to the front.
Thanks for the info and pics!
Old 03-19-2014, 06:32 AM
Power, can high/low and earth. Take a look here.. It's pre-lci pinouts but maybe it's pretty much the same. I followed this OEM instruction http://zorc.net/misc/online/E90_PDC_Retrofit.pdf
And you will need something like this.. Buttons http://www.ebay.com/itm/BMW-E60-LCI-...ht_2765wt_1153 Try to find those with your existing equipment and + the PDC button for the retrofit ofc.
Yes, again its controlled by SZM.. Buttons do not need coding as they're connected with the switch control center already.
Retrofit kit or not, the parts is easy to find if you search. Also it gets cheaper from junkyard. Coding was for free Dont think its pre-wired tho.
Alpina B5 #001
Old 07-25-2016, 06:10 AM
jimbobcress jimbobcress is offline
Mein Auto: BMW E60 525I
Hi, I'm in the middle of doing a pdc retrofit to my 5 series, and am wondering if anybody who has done it as well could advise on what options to change in the coding stage. I have a 2004 525i with no pdc fitted as standard and with the standard mask stereo option. It is pre lci and has the DSC button like the picture in F-tar's post but with out the heated seats. I can see there are pdc options in the mask trace file but would like to know what you may of selected to get yours working. Also is there a loom for the pdc button in the dash or will i need to wire one in myself?
Help appreciated if anyone is still looking at this post.
Old 07-26-2016, 06:53 AM
Just get the switch center console with pdc. Just make sure if u got 2 or 3 connections back there.
For this to work you need to add $508 to VO. Then code MASK default. Not much more to it. Have fun
Alpina B5 #001
Old 08-01-2016, 05:48 AM
Ok so i hit a metaphorical wall on the weekend. I installed the module and sensors and wired them in ok i think. Received the pdc switch, and after removing the old switch i discovered im missing a connector. Its a 12 pin camlock type. Without it the car can see the pdc module and i have been able to change the VO and mask config, but norhing comes up on screen apart from a pdc malfunction.
Where does this connector go? No mention is made on the bmw retrofit instructions which i used to wire up the module in the boot.
Could someone look at theirs and note the wire colous and pin connections. I would like to try and find out how to wire this in myself.
Old 08-05-2016, 01:26 PM
Sorted it after some investigation and a friend who let me take their dash apart!.
All you need to to connect the switch/module to the cars k-can system. Just 2 wires.
If you have no other switch apart from the DSC button then you will likely only have a small 6 pin connector, But the console switch you need has a 12 pin connector on the back as well. All you need to do is take 2 wires from pin 11 and 12 of the connector ( make 11 black and 12 yellow and connect them to the nearest twisted black and yellow wires you can find. Conveniently there is some just above in the IHKA wiring. There is a 18pin connector on the back right of the heater controls, there is a black and yellow on that connector. just splice them in. And voila opne working pdc switch.
Thanks to all above for the info to get me this far.
pdc, pdc coding, pdc programming, pdc retrofit
