Old 10-10-2012, 11:06 AM
JimmyW JimmyW is offline
Mein Auto: 2002 BMW 745i
Dealership Can't Program Car
I finally retrofit installed the whole Active Cruise Control System into my car and got the sensor aligned by the dealership. I coded the active cruise control myself using NCS Expert to all of the modules. After the alignment the only error code left was from the DSC module. I realized I never programmed the DSC module with the Active Cruise Control info because it doesn't show up in NCS Expert! So with that, I brought it back to the dealership a second time for them to program it with ISIS. Well.... I just got an e-mail from the dealership saying they won't be able to program the car because of other retrofits I've done (Navi03, facelift MMI, steering wheel heating, and steptronic). Has anyone that ran into this same problem (retrofits causing coding problems) solved it? Or does anyone have any better software than I do for coding the DSC module? I'm in the Metro Detroit Area.
Old 10-10-2012, 01:57 PM
mrbmwx5 mrbmwx5 is offline
Mein Auto: 06 750Li
What dealer did you took your car to?
2001 X5 3.0i 200k miles & counting...( SOLD)
Dinan Stage 1 Trans and Engine /SMG M3 Steering wheel/M5 SMG shifter/BMW rear entertainment/4.6IS body kit/4.8is Exhaust/ X-pipe/Turner HP Pulleys/E92 sport seats/Group M Intake/Brembo drilled rotors/Quart projector beams headlights
06 750Li with 19k miles.
Bone stock.
Old 10-10-2012, 01:59 PM
Mein Auto: 06 750Li
My guys at Erhard can do any thing ...
Bone stock.
Old 10-10-2012, 02:17 PM
It was Erhard. I just spoke with the tech directly. ISSS does not allow you to program individual modules. It's kinda "dumbed down" and won't continue without them replacing the SZL, MMI, NAVI03 unit.
Old 10-10-2012, 04:06 PM
Mein Auto: 06 750Li
Talk to Sam and Chen at Bloomfield Hills location....The rest of those tech at Farmington Hills location they lazy and....
Bone stock.
Old 10-11-2012, 08:33 AM
To CCCP: I have been trying to get ahold of Ace by e-mail and PM but haven't gotten any answer. I am the one that bought the active cruise kit
To MrBMWX5: Thanks for the advice, I'll give the bloomfield location a try!
Old 10-10-2012, 02:24 PM
***CCCP***'s Avatar
***CCCP*** ***CCCP*** is online now
Major
Mein Auto: 745 li
Talk to ACE he knows how to code it using dashsoft he was selling active cruise set up at one point.
Old 10-11-2012, 03:39 PM
***CCCP***'s Avatar
Major
Mein Auto: 745 li
Ill talk to him tonight and ill let him know.
Old 10-12-2012, 08:06 PM
rippjd rippjd is offline
Mein Auto: '05 745i / '00 740i
I finally retrofit installed the whole Active Cruise Control System into my car and got the sensor aligned by the dealership. I coded the active cruise control myself using NCS Expert to all of the modules. After the alignment the only error code left was from the DSC module. ....
Any plans to do a write-up on your retrofit? Some day I plan to add this option.
2005 745i Individual
Old 10-16-2012, 05:21 AM
I do! I know what to do as far as getting everything installed. There is only one step preventing me from activating the cruise control. When I turn it on, it says ACC Malfunction! Maintain safe distance. And the car immediately stores an error in the ACC module saying "implausible signal sent" and the DSC module says "implausible signal received. Acc deceleration request too high". The technicians at the dealer knew the DSC module was the module that needed to be coded with the active cruise option but I'm stuck figuring out a way to do so. Either I will need to find factory stock modules (SZL, iDrive knob, MMI, and navigation unit) and switch them out (what a PITA that would be!) or I need some software that will allow me to code only the DSC module. Then I will try my best to do a full write up with any gotchas I encountered along the way
Old 10-20-2012, 01:55 PM
The technicians at the dealer knew the DSC module was the module that needed to be coded with the active cruise option...
How does the Dealer (and you) know the DSC module needs to be coded? As you said, there aren't any DSC coding files in NCSExpert... nor even in the SPDaten packs, so I'm thinking the module is not codable, just programable.
Looking in ETK, the 2 part numbers listed for the DSC electronics unit show effectivity of only the E65 & E66. Typically when BMW does this they don't make the unit codable.
Also, you have a MY2002. ACC wasn't an option until MY2003. Some modules likely need newer software, though I would expect a full I-level update would have accomplished this, and surely your car has had an update in the past.
Do you know your DSC's hardware and software part numbers?
Old 10-25-2012, 06:23 AM
I just came to that conclusion because based on remembering that I never coded the DSC module and that the error message "implausible signal" was very strange and suggested that it didn't understand the commands it was getting from the ACC module.
That is a very good and interesting point about the part numbers, I never knew that!
I knew the ACC module wasn't available until 2003 and was worried it wouldn't even have a place to fit in the car, but surprisingly, if you look at the bumper there are holes for the bracket. Talk about smart engineering!
My laptop is dead right now, after I buy a new laptop and get it set up I will look for the DSC software and hardware numbers w/ INPA for you. I also need to do some programming for another local member of the forum and I think he said he's willing to swap DSC modules w/ me to see if that gets the active cruise working
Old 11-29-2012, 06:56 AM
Post
Here is the latest update on this issue:
I swapped DSC modules with a MY 2004 DSC Module (mine is 2002). It still didn't work but the errors are behaving differently now. With my original DSC module, when you pulled the stalk to activate cruise, you'd get the error and for the rest of the drive (until the car is turned off and back on) you couldn't activate the error again. Well now with this new module, when you get the error, it only remains in the iDrive for a few seconds and then disappears and you can pull the stalk again and it'll chime and error again. I've attached a picture of the iDrive screen error. I've also attached the DIS screenshot showing the new errors. "No activation possible" and "no deceleration or acceleration possible". Running through the tests is useless (it just tests whether the buttons on the stalk are working properly and then quits.
I've also attached screenshots of the info display in DIS. I think you are right rippjd, the module doesn't need any coding. But now I'm still stuck as to what is causing the issue.
ID:	351291   Click image for larger version
ID:	351292   Click image for larger version
ID:	351293   Click image for larger version
ID:	351294   Click image for larger version
ID:	351296   Click image for larger version
ID:	351297   Click image for larger version
ID:	351298   Click image for larger version
ID:	351299   Click image for larger version
ID:	351301   Click image for larger version
ID:	351302   Click image for larger version
Old 12-07-2012, 06:05 PM
Looks like most of the modules don't need to be coded as "variant recognition" occurs automatically with the first message from the ACC module. It's almost like there is something preventing communication. I assume you've re-checked the wiring per WDS?
Progman could do the formal conversion for all the control modules, but you would likely need to first change your VO to a Euro type, as ACC retrofit was never officially offered in North America US spec 7er.
For what it's worth, attached is the training module on the E65 ACC. Note this is not for ACC2 introduced in the 2006 model year.
