BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
Is it possible to swap Quaife LSD from 335i to 335d?
I know the open differential is welded on for our 335d vehicles. Is it possible to take an existing Quaife LSD on a 335i and put it on our 335d or are both LSD units for either model built differently?
Thanks. |
Call Lenney as I infoed you in the other site, and good luck
GBD, I think you'll need to address the difference in final drive ratios. From the factory, the 335i is 3.462, and our d is 2.813. I don't know if Quaife varies final drives or not, but that would be the central issue, as I would assume the fitment would be the same. Can you contact Quaife directly?
I know one user put an aftermarket diff. into his to get the same end result I think you are looking for. Are you though talking of just swapping the diffs or much more than that? If just diffs then wouldn't that mean swapping the ring and pinion?
--Aaron |
thats an expensive swap wont a QUAIFE be a better solution
