Go Back   Bimmerfest - BMW Forums > The Best of Bimmerfest! > Forced Induction
Forced Induction
Aftermarket superchargers & turbos as well as tuning for stock BMW turbos (N54 motor - 135i / 335i / 535i). Force-fed discussion to make your car go faster
Old 10-17-2012, 07:13 PM
E30949/909 E30949/909 is offline
Mein Auto: 1990 325IC
Turbo M20B25
What's the best turbo setup for this motor that can be put on a bone stock engine?
Old 12-11-2012, 05:26 PM
Microtesties Microtesties is offline
Unregistered User
Mein Auto: 1990 BMW 525i
I have an E34 with an M20B25 motor. Unfortunately as far as I can see they aren't really fit for any kind of aggressive forced induction. You could build some kind of ram air intake though. Post pics if you do build something!
Year: 1990
Model: 525i
Transmission: 5 speed
Mileage: 250k
Old 12-18-2012, 09:12 AM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 85' 335i
T-28 from a dsm... or maybe a 16g. The motors have a 8.5:1 compression. I would at the very least buy: MLS headgasket, arp head studs, injectors, and a tune. Otherwise, you'll boost maybe 3-5psi and fuel cut. In that case, don't waste your time.
1985 335i
Black on Black coupe 5spd
Tokico lowering springs, KYB struts and shocks, BavAuto strut bars, SPC adjustable camber plates, Ireland Engineering rear toe and camber kit, Sparco buckets, Rota Torque 16x7 fronts 17x9.5 rear, Hella headlamps with HID conversion, all red taillights, MSD coil,M30B35 swap
http://www.bimmerfest.com/forums/sho...36#post7573736
M20B27 for sale in Cincinnati
