Car will not crank when key is turned
My car has been working witout any problem. I came home 3 days ago with car working fine and parked the car for 2 days. On the third day I went to turn the key and no action watsoever not even a click. Had radio and all warning lights lit up as well as the front lights and AC fan. Nevertheless I figured it was the battery and bought a new one and changed it out. When I went to start much to my surprise no response at all. I checked the voltage in the jumping terminal under the hood and the voltage was 12.5 Volts. I worked the windos and no problem.
I did notice that when I closed the doors the windows did not close the 1" that is usually open in verts. But after I operated them from the car switches then they started to open and close the 1 inch when door is open. I have no idea of what could be happening I have done nothing other than look at the fluid reservoir for the top hydraulic pump since I'm having a problem raising or lowering the top. I have no security system on the car but I understand the car has some theft deterrent gizmo. Can someting in this area be malfunctioning. I did notice there is a fuse called "starter interlock" but I don't have that fuse. DOES ANYBODY HAVE AN IDEA OF WHAT COULD BE HAPPENING! PLEASE HELP!!!! If I can get it started I will have to tow to a mechanic. BTW my car is a 2004 325CI vert E-46 body. |
Suspect your starter motor.
How skilled are you? Check the engine ground strap. Rap on starter motor with heavy piece of metal. Check voltage at the starter motor on the large terminal. If OK there, check voltage at the starter on the small terminal when turning the key to try to start your car. Come back with results if necessary. |
Goforth, thanks for your reply. I agree with your suggestion 100% but the problem is that on the 325CI vert the motor is totally covered and there is no way to access the starter or the terminals from above. According to mechanics its only available from under the car but unless its on a lift its impossible to access from below. Your sugesstion is what I used to do on older American cars but not possible with the BMW. I'm not too skilled but certainly know how to use a voltmeter and understand electrical circuits very well and could (if accessible) tap the starter motor. MY guess is that is probably the starter motor or the start ckt but from some people I have heard that before the switch connects the voltage to the start motor it first must have too other interlocks close. So it could also be one of these interlocks that has cropped out. I guess an indy shop that has the code reading tool may be able to check this. |
and you forget to mention testing for amperage draw from starter motor. much easier to do starter replacement from the bottom. i wouldnt attempt to do this from the top its a waste of time.
iATN
Again to measure amp draw I would need to access the terminals. |
starter removal on a automatic transimission is easier from the top. per Bentley's, on all wheel drive, it "may be" easier to remove starter with the transmission lowered 5cm? glad I don't have to go there. |
If the solenoid is dead, this will not work? |
Based on this since my lights did not dim and no sound was heard I'm pretty confident my problem is the solenoid and I would also change the starter because I have heard its a difficult job to do. Anybody have any idea what the starte motor cost? How about the labor to change? (hours ) |
Suspect you won't get a code on this. Bet you have no dash light?
Others have done complete starter motor replacements from up above, so your mechanic info is not valid. Have not done it myself, but read more than on online reports. You could search for an excellent DIY for the starter motor over at e46Fanatics.com. |
You are probably right and he is no my mechanic but since I have no idea and when i poke my head in the engine all I see is an engine wrapped in plastic and no visible parts. Good input on the DYI link I will try today. thanks! |
No need for current draw test. You'd know it if hundreds of amps were flowing without an ammeter.
If you hear no click, you are not pulling the solenoid in. I meant no light on dash indicating codes were thrown! Not dash lights. Starter solenoid is one piece. No one replaces just one. Rough guess 4-5 hours at the dealer. Let's not skip the basics. You still have not established that you are getting voltage to the solenoid terminal on the starter when atempting to crank. You jumped right to thinking it's the solenoid. Use some science here. Just for the mental exercise, you could measure starter current by opening the circuit over at the jump terminal in the drug bin. But don't do this. You are very green when it comes to working on an e46. You don't even have the rudimentary knowledge to remove the airbox, MAF. intake hoses, rain tray along with battery cable from one side of the car to the other. And power steering compartment divider. The aforementioned are all basic to getting to many important areas on an e46, includiing the starter. Necessary to lurk here for a whiile to gain all this insight. You are starting with one of the nastiest jobs. Learn to use www.realoem.com to find part numbers for your VIN. Then plug them into the various suppliers listed here: www.furiousmethod.com Here is a pic of the starter bolts accessed from the top. Not sure if auto or manual, but honestly on this one thank heaven I have not had to do a starter! Last edited by GoForthFast; 10-21-2012 at 08:27 PM. |
and how would you know if it was drawing sufficient amperage without an ammeter? explain. Quote:
if it dont work obviously he needs a starter.
iATN
But we still haven't tested for voltage at the starter as measured to the ground of the engine rather than the ground of the car body to establish whether or not the ground strap is sound. Must eliminate every possibility until you find the problem. see pic of ground strap |
but you telling him to check ground strap (excessive resistance if loose or corroded) would cause insufficient amperage draw. which again, could be indicated by doing an amperage draw test on the starter. i dont know why you keep ruling out current draw test as worthless. it is obvious you do not have experience in the automotive field based on your "current draw test worthless" assumption. Quote:
iATN
Do you have an ammeter capable of measurng three or four hundred DC amps? Last edited by GoForthFast; 10-21-2012 at 10:13 PM. |
thanks for your input. You are right I'm green but learning fast and anxious to keep learning. I can remove the airbox and other items like replacing the battery but I have no idea what the MAF is or how to get to the starter. I also placed an ammeter in series with the battery and tried to start and there was no current draw which if the circuit is complete would indicate a faulty coil or an interlock opening the ckt like the ews system. You are right about the nasty nature and Im afraid I will have to resort to an independent mechanic not necessarily a BMW one since all good mechanics know how to change a starter. I know how to use www.realoem.com but it does not list the price of the starter can you believe. I will try your other URL since I believe I have a part number but I need to check with the stealer. By the way you forgot the picture. Please post it and thanks for all the great help. |
i commend you for looking for information to try and diagnose this yourself but to me this is over your head. not just you, this is the case for probably 95% of the people on these forums. i'd take it to a reputable shop if i were you and be done with the headaches.
iATN
But I agree with you changing the starter is such a nasty job that i will have to take it to a mechanic but the problem is finding an independent one that is, as you say, reputable. |
Please take a picture of this for me? I am preparing to be amazed!
Do you use welding cables for this measurement? |
MAF is Mass Airflow Sensor starter is under the two rubber intake boots that connect the MAF to the throttle body and ICV. Don't ever put an ammeter in series with the starter motor again unless you have one capable of hundreds of amps? Where did you get that? If you want to use a meter, use an ohmmeter to measure the resistance of the solenoid coil. Lots of mechanics can do starters. The trick here is familiarity with access on an e46. Find one who can do this or he'll be starting from where you are right now. Here's the starter listed with part #: http://realoem.com/bmw/showparts.do?...92&hg=12&fg=25 And not hard to find with what I gave you: http://www.rmeuropean.com/search.asp...rd=12412179001 Last edited by GoForthFast; 10-21-2012 at 10:09 PM. |
Thanks for the links I did use them and found the part and price. thanks!
also i never said to knock on the starter motor. i said to jump the terminals to bypass solenoid and apply direct battery power to the starter. you can use a flash light and see where the terminals are from the top of the engine. no hard feelings here best of luck to you.
iATN
Chan I really appreciate your help since I'm green on the repair dept and anxious to learn. You have given me excellent suggestions which i have applied. The knocking the starter was not suggested by you but I have done that in american cars and sometimes work. I did connected the Ammeter in series to measure ma parasitic currents as well as the hook on. Acyually there is a diy in the net for measuring parasitic currents where i got the idea. |
#25
here is a link to a video that shows exactly how i connected the ammeter in series to check for parasitic currents: Enjoy and thanks for all your help and input. |
