BMW Diesel Owners / Enthusiasts
Do you own a diesel powered BMW? Maybe a 335d or a BMW x35d? Come and talk about what makes your car great! |
R17 to R18?
Already swapped out the base suspension for the Performance Suspension but still have the OEM R17 wheels. Tires are worn enough that it is about time for new ones and I thought I would go with a R18 rim with more width and stagger. What cracks my head is all the talk about offsets and other mods that I would need to do that. Can anyone help me out and explain what I would need in addition to the wheels to swap in style 287s, 193s, or 195s?
I had no idea what this thread was about. Never heard of wheel size referred to as Rx either. Spacers may cause vibration at high speed, even if they are hubcentric and over 11mm thick.
FS: 19" HRE 840R's/Tires/TPMS http://www.bimmerfest.com/forums/sho...94#post7186394
It all depends on how "flush" you want your wheels to look with your fender. If your wheels are the same width you will need to run a bigger spacer in back then in the front to really get that staggered look. If you are looking for a "flush" look the spacer size will depend on your wheel offset. Any spacer over 5mm I recommend hubcentric otherwise your hub has enough lip to run 3mm to 5mm and still be hubcentric. VAC Motorsports sells some of the nicest/best spacers on the market IMO - talk to Chris Bull he'll take good car of you.
Thank you very much Labalamp425 and cssnms (and all). This is exactly the sort of info I was seeking. Nothing seemed more confusing to me that all the discussions around wheels. There are a great many wheels available used and I'm think of keeping my 17 inch rims for winter driving, as they have a set of PS2 A/S on them and picking up a used set of 287 rims for the summer. I was really hoping that that could just be a swap without doing anything other than balancing.
You should be fine doing a straight swap. My 335i coupe has the sport package with staggered summer tires, but for winter I have a separate set of 17-inch wheels with 225/45R17 tires all around. I do the swap myself and have no issues.
If you want to go up to 19-inch wheels (not sure why you would, but throwing it out there) the OEM sizing is 225/35R19 front and 255/30R19 rear.
2007 E92 335i ex 1991 E34 525i (M50) |
Thanks again for the advice Lavalamp.
