Old 10-21-2012, 02:39 AM
artinstead artinstead is offline
Mein Auto: 2005 x3
clunky noise 1st, 2nd gear
Have a manual trans and there is a clunk noise when depressing clutch going from 1st to 2nd and depressing clutch to go back to 1st at low rpm maybe 1k-2k in parking lot situations at low speeds 10-15 mph, where you could probably remain in 1st gear. The noise only occurs after the engine has warmed up, 20 mins or so
It doesn't happen on street driving say starting out at the green lite to get to the speed imit shifting at higher rpms 2k-3k but just when you're creeping through a parking lot. I've got an extended warranty thru next april and will take to dealer unless it's just a normal sound in low speed situations. Anyone experienced this? Thanks.
Old 10-21-2012, 07:50 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
My '09 is quiet as a mouse so it's definitely not normal. I would have it looked at.
Old 10-21-2012, 01:27 PM
Mein Auto: 2005 x3
Yeah I figured, thanx
Old 10-22-2012, 01:07 PM
jdauria jdauria is offline
Mein Auto: E39 ///M5
rear diff mounts, guibo
Good thing is your still under warranty so have them do it fo free
2000 ///M5 ///M Registry (09/99 Build)
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | AT | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 10-22-2012, 05:47 PM
chewchewone chewchewone is offline
Mein Auto: X3
i've been experiencing the same thing for about 9 mos now ( same symptoms like you describe). I took it to the dealer the first time, the SA had no clue, then the second time....the mechanic supposedly checked it , they said that it was my transfer case motor ( they didn't even bother driving it, they just read what the SA wrote which I didnt get to read after it was time to pay the bill (bad on my part...lesson learned). All it said was "noise under the vehicle". Anyway, i declined the transfer case replacement... changed the fluid myself, seemed to have lessen the clunk but i think its all psychological. The more i listen to it, i think it might actually be the Clutch Delay Valve (CDV)....... Please share if you find out what's making that clunk.
Old 10-24-2012, 06:31 PM
Mein Auto: 2005 x3
will do, got appointment 11/9
Old 11-11-2012, 09:04 AM
Mein Auto: X3
Were they able to find out what's causing the clunk?
Old 11-11-2012, 04:50 PM
Mein Auto: 2005 x3
a
Old 11-11-2012, 04:52 PM
Mein Auto: 2005 x3
I told them of a rattle or clunk sound between 1st and 2nd when clutch depressed. After cheking it out determined, was nothing abnormal just drivetrain backlash at those low rpms. http://www.allfordmustangs.com/forum...-backlash.html
