Old 10-21-2012, 07:28 PM
jblair85 jblair85 is offline
Mein Auto: 2005 325i
2005 325i - Clunking Noise
My bimmer has right under 100k miles. I just replaced both control arms, ball joints, and bushings and had my vehicle aligned. Shortly after I am now hearing a clunking noise while driving the vehicle which occurs primarily while braking hard. It also happens while turning. Not a repeated clunk like a CV joint but more of a single "POP!". I know that I still have the factory struts and engine mounts but these items appear to be fine from close inspection. Does anyone have any suggestions on what this may be?
I have already taken the vehicle into the shop that performed the alignment and they said the alignment is fine...when asking them about the noise they suggested it may be the engine mount (but I can't see the engine mount being loose at all). Any input would be greatly appreciated thanks!
Old 10-21-2012, 08:30 PM
Fast Bob's Avatar
Keeping it surreal
Diff bushing, maybe ?
The road goes ever onward....
(R.I.P. Jever)
Old 11-04-2012, 06:32 PM
Thanks for the reply! I will check into this next time I get a chance to get under the car. I looked around on youtube and found a couple of examples. It does seem like the noise is coming from closer to the front of the vehicle but anything helps.
Old 11-04-2012, 07:41 PM
JayMac JayMac is offline
Mein Auto: 01 M3, 83 320is, 75 2002
Just a thought but make sure your calipers are on tight. Had work done at a shop and a few weeks later the caliper came off while driving. Bolts had backed out.
Old 11-04-2012, 08:01 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
It sounds like FCAB's. Get under it and make sure the FCAB's were installed correctly and not on top of the bushings. A visible gap between the FCAB and its mounting point will be noted if it is not installed correctly.
You could also visually inspect motor mounts while down there and try to pry between mount and sub frame to see if it is a bad MM.
Old 11-05-2012, 04:32 AM
jdauria jdauria is offline
Mein Auto: E39 ///M5
RSM, Subframe, engine mounts (the rubber dries up and starts to crack), etc
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Black Birch |
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers
SuperSprint X-Pipe
Storm Motorwerks Products
2011 X5 35d | Alpine White | Beige | Sports Pkg | Premium Pkg | Cold Weather Pkg | 3rd Row
2003 X5 4.6iS | Black Sapphire Metallic | Black Sport | DINAN Software | FOR SALE!
Old 11-05-2012, 05:37 AM
1972ford's Avatar
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
Does it ever happen when you go over bumps? Or just braking? More when turning one way or the other?
Old 11-23-2012, 02:07 PM
Response to 1972 Ford
The noise happens all the time when braking moderately hard as I keep on letting it go it is beginning to happen more often (like going over bumps etc.). I tried to check it out again and was unsuccessful so I will be taking it in on Monday.
Old 11-09-2012, 09:01 AM
mafabix mafabix is offline
Mein Auto: BMW 318i
I have exactly the same problem!!
Old 11-09-2012, 10:05 PM
Guys check your camber bolts. Number 10 in this diagram.
I had forgotten about those. I was tracking my son'e e36 and I would get a single pop when cornering hard. I could feel it through the aluminum race seats and it drove me nuts. We checked everything and tore the rear end apart. In the end it turned out to be the camber bolts had rusted pretty bad and would shift when loaded up. SOunds like that might be what you are experiencing. Easy check and fix. Good luck!
Old 11-10-2012, 09:15 AM
Y2K_Bimmer Y2K_Bimmer is offline
Mein Auto: 2000 323i
I had a clunk in the rear when I would shift in lower gears. The part , rear diff bsuhing, wasn't expensive but had to take it to the shop. Ened up being about $500. The bushing was totally shot when they showed me. They also said it was hard to get off so I'm glad I didn't try this one in my carport.
Old 11-23-2012, 02:28 PM
crsandoval crsandoval is offline
Mein Auto: 2004 325Ci SULEV
I need to replace the rear diff bushing as well. It has an occasional pop as well. Shop here in CA quoted the same amount.
Old 11-23-2012, 06:14 PM
stilover stilover is offline
Strut mounts maybe? I had similar noises to what you are experiencing, only not in cornering, mainly when hitting bumps.
Old 12-21-2012, 06:52 PM
Just to wrap this one up. I took my vehicle into the shop and they could not find anything broken or worn. They ended up just lifting the vehicle on a floor lift to put weight on the suspension and then they tightened down on the bolts all around where the control arm bushing and ball joints were installed. This was it....no charge either.
