E36 (1991 - 1999)
The E36 chassis 3-Series BMW was a huge hit among driving enthusiasts from the first moment the car hit the pavement. The E36 won numerous awards over the years it was produced and is still a favorite of many BMW enthusiasts to this day! -- View the E36 Wiki |
M3 swap into a non vanos
I have a 92 non vanos car an just picked up a 99 m3 drivetrain minus ecu an harness can anyone give me some help on how to make this swap work. Thanks!
Sent from my PG86100 using Bimmer App |
You will need an ECU and harness for your drivetrain.
1998 BMW 328is 1966 Pontiac GTO 2007 Subaru Impreza 2.5i 5-door View my photos: Caught in the Wild |
Most likely one from M50tu (Vanos)
I've heard that I can use an obd1 vanos harness and ecu has anybody done this?
Yep tons of people. Google S52 OBD1 conversion. You will need a vanos harness and probably a red label dme.
-Alan ![]() Member #2 of the Boston Green Mafia BMW-CCA #457574 1995 BG M3 2000 TiAg 4.4l X5 -I do the things today that others won't do, so I will have the things tomorrow that other won't have.... |
Use your M50's intake manifold, along with the rest of the intake system (except injectors). Use the exhaust from the S52. You can use either valve cover, but you'll need to make an adapter for the crankcase vent if you use the S52 one. Also, you'll need an S52 chip for your red label DME. You can get one from the big companies, such as Turner, or you can talk to an independent tuner.
-CJ
where in jersey are you?? i have red label dme, 413 (iirc)
and like these guys already said, a harness would be necessary. be preppared for a bit of work. df
