General BMW
Use this forum to talk about general BMW news/stories and to chat with fellow enthusiasts about the direction that BMW is going in for their cars and/or motorcycles! |
flat with a run flat -- I want to hear your experience!
This evening, I happened to hit a curb (not paying enough attention
while making a turn), and subsequently had a flat. Called AAA, swapped my full size spare in place of the flat tire (took all of 20 min), following which I went to get dinner, and then drove back home (about 40 miles away). I'll get the flat fixed at leisure. How would this have been handled on a car with run flats? Is the mileage limit after a flat always fully available or does it get reduced, if for example, you were to leave the car parked somewhere overnight, and then try to drive back home later or the next day? How does it get handled if you call roadside assistance and you're further than the limits allowed by the run flat? Do they come in with a spare? Do they just tow the car to your home? If you have had a flat with run flat tires, I would like to hear how you handled the situation and how long it took to get resolved. Thanks!
2003 325i / Gray Green / Beige Leatherette / 4 Dr / 5-spd / Base car with moonroof / 210K+ Miles Last edited by mr_clueless; 10-23-2012 at 12:16 PM. |
Thank goodness i toss all my run flats as soon as i can... so no experience here
but i did want to share a similar personal story with regular tires and a spare. I was traveling with my kid and got a flat, swapped out the flat tire with the spare and was off in 15 mins... If i had run flats, I might have been able to drive back home, but its a big IF.... if the damage was too bad, i would have needed a tow truck to take a car, and my wife to pick up, because there is no way my kid is ridding in a tow truck..... My 2 cents....
![]() | Bimmerzone.com | 1-800-357-7797 | info@bimmerzone.com | 833 Lincoln Ave, Suite 5, West Chester PA 19380 | Video about Bimmerzone: http://www.youtube.com/watch?v=me5pjPS88Bw We are proud to be Authorized Dealers for: Sprint Booster, Peake Research, Eisenmann Exhaust, Hartge, RPI Exhaust, AutoEnginuity, Bentley Publishers, Zymol, P21S, PowerFlex USA, Brembo GT, KW, Hawk and much more!! |
On my 2005 530i I hit a very bad pot hole on Christmas Eve and figured I would do what they suggest,drive under 50 mph but that didn't workout for me as the flat was to bad to do that so I pull over and called BMW Assist. They came within 1/2 hour and changed the tire for me and I was I my way. A few days later I went to the dealer,JMK BMW, and they replaced the tire under insurance and checked the rim that was ok. End of story.
cheers vern
If you hit a curb that suggests your sidewall was damaged and I don't think anyone will repair sidewall damage in any type of tire. I believe the difference between runflats and non-rf tires is that the side wall is "heavy" and can support the weight of the car until you get to a safe place - maybe a puncture in the tread could be repaired by an independent but a hole in the sidewall is a different story.
My car is old and had a full-size spare, so I was back in business in 20 min. I started this thread to ask people how they would have handled such a situation in a car with run flats and without a spare. It sounds like Vern already said that run flats did not help in one of his situations, but it sounds like he too had a spare. What happens in such a situation if there is no spare and it's too late in the day for any shop that would have such run flats in stock to be open? Do emergency services have a supply of run flats? Or do you just tow the car to the dealer/shop and take a cab home and figure out how to deal with it the next day?
2003 325i / Gray Green / Beige Leatherette / 4 Dr / 5-spd / Base car with moonroof / 210K+ Miles |
cheers' vern
All I ever get is slow leaks from running over nails/screws.
Even then, a normal go flat tire with a low aspect ratio is fine as long as you keep the pressure up. |
Can't stand them. Noisy and rough, and I've had two flats on both my 6 and 7 series this year alone. 6 series cost me 6 hours and a $300 dollar tow because the tire only lasted 20 miles even at 50 mph lightly loaded before sidewall separated. That in turn cost me the whole tire ($500)...if I'd had a spare I would have only suffered 10 min delay and 15 dollar punture repair. So $750 loss and time delay on the first one.
Second one was on the 7 two weeks ago. Stranded in a town for two days while I had a tire overnighted (none in town either RF or non RF in that size)-cost $700 plus the lost time. I was able to limp around town on the RF in this case, but didn't dare venture out of town. Bottom line, heavy cars cannot handle RF tires, and having no spare is irrational on a luxury car, especially when so much of America is 100's of miles from any city/towns that have tire selection. |
2009 750Li-Sport Pkg, Active cruise, HUD, Lux seat, Rear Enter, Conven, Prem Sound 2005 645ci 2003 745Li (sold) |
Even in that class, it looks like the Lexus LS is the only car that offers a full size spare.
cheers vern
wow, thats a tough one.....
in the end, both tires has its pros and cons... none is perfect... Quote:
Had a a nail in one of my tires and a chunk taken out of the inside sidewall of my RFT on my 528i. Got the warning but didn't see the damage, only the nail. I continued to drive my car without any problems with the damaged tire until it was repaired. So I've had no problems using the RFT's as advertised.
My partner had torn out a side wall on one of her tires. (Long story -Don't go there, pilgrim). Anyway the next day I drove the car to my workshop where I had a spare RF wheel ready to go on. I drove on a tire with a 2 x 3 inch sidewall rip at speeds up to 40mph (60kph) a distance of 30km (you work it out). There was no real difference in the car's performance or handling. Left rear was the damaged tire. I believe that MINI Roadside Assist will bring a wheel if required, even if it is a 'loaner'.
Drive a 2008 335i Coupe, purchased new, fitted with Pilot Sport 2 18in. Had a flat warning light come on at 4800km, stopped and found a posidrive screw thru the face of the left rear. Drove at 70k/hr for 30 odd kilometers to a tyre centre where they removed the tyre and inserted a plug. No problem with the handling or anything during the drive. Have just replaced the tyre, 49100km and 3 years later, as it is finished and did not have a single problem during that time. Runflats do have an advantage, in my opinion, BUT, the non RF's do have a better driving feel and are quieter. My son has non RF's on his Z4, and definately is better than the RF's.
How damaging is it to drive a car with a fully flat tire (non-RFT)? I see people changing their tires on the freeway all the time, dangerous as heck. Their butt is hanging out ready to be clipped by someone going 70.
I've never gotten a flat on the highway before but I assumed that unless the tire was shredded and fell off the rim, I'd be driving it slowly to the nearest off-ramp before swapping it out. |
But I think the main issue is that you can't really drive a car with a flat at anywhere close to freeway speeds...one could probably limp along the shoulder at 10-20 mph and take the next exit, but I don't think the tire will have any chance of being saved at that point.
I'd rather do that than risk my life changing a tire on the freeway. Not to mention the traffic you would cause by blocking up traffic. Best to limp it to the next exit and pull off the highway, even if it means a new tire.
I agree that run flats are rougher and noisier but do offer safety and convenience. I cannot offer experience on a larger car but on my 3 MINIs they work fine and mean my partner or daughter can drive to safety, or home. Non RF will be destroyed in 200 yards (or less) of total flat driving. $500 rim to follow in the next 200 yards. Also warning light on dash lets them know when a problem has occurred.
Neither my E23, E30 nor my E38 have tyre deflation warning lights. They rely on driver awareness. My daughter is good (and would probably notice a problem). RF's are safer and better for ladies driving alone. Can there be a limit as to how many idiot lights an idiot driver needs?
I want the idiots around me to have as many lights and buzzers and bells as necessary to keep them from hitting me or my family. If TPMS alerts the other driver to a low tire and it avoids him suffering a front wheel blowout at 75MPH and swerving into someone, then I'm all for it being in every car out there.
#25
god must like me. I've never had a situation where a flat occurred while away from home. I hear nothing but sad stories about run flat tires. They go flat too?
I would get rid of them ASAP if I had them on a new car.
Everybody is a genius. But if you judge a fish by its ability to climb a tree, it will live its whole life believing that it is stupid. Albert Einstein Swim upstream. Go the other way. Ignore the conventional wisdom. If everybody is doing it one way, there’s a good chance you can find your niche by going exactly in the opposite direction", Sam Walton. |
