Old 10-28-2012, 01:39 PM
DIY'er
Mein Auto: 2004 545i
How to: ZF 6HP26 Mechatronics Solenoid Replacement / Valve body removal
Here is a quick video I did on removing the valve body/mechatronics on my E60 yesterday. I ran out of space on my memory card before I finished so there's not any video of it going back together, but it's pretty much just reverse from coming out.
Instead of replacing the whole valve body / mechatronics assembly, I replaced just the solenoids and it completely fixed all of my issues (slow shifting to reverse, rough shifts everywhere, jerky shifts 5 to 6 and 3 to 2 especially, hiccup in 5th, etc. etc.) Hopefully this will help someone.. It appears most E60 owners do not do as much DIY on this kind of thing as me. Let me know if any questions.
Hopefully this saves someone some money!
Also, about 3/4 of the way through the video it keeps stopping for me and acting like it's the end. It isn't, so make sure to watch the end.
Wish I could have gotten more detail on changing solenoids and re-installation, but I'm not doing it again for the sake of a video
Old 10-28-2012, 04:56 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Thats diving right in. Thanks for sharing the Diy.
Old 10-28-2012, 05:14 PM
Jaystyles's Avatar
Jaystyles Jaystyles is offline
Mein Auto: 545i Sport
Thumbs up Great Job!!
I've been experiencing the slow shift into reverse as well. I'm going to have my guy take a look at your video and see if he could do just that instead of changing out the entire valve body unit in my transmission of my 2004 545i.
Old 10-28-2012, 05:22 PM
DIY'er
No problem! It wouldn't have been so bad if I had had another car to drive if I messed something up, lol. But this is my only car right now. No pressure
He shouldn't have any trouble. thectsc has the parts. If he has any questions just PM me or post them here and I'll try to answer them.
Make sure you get enough fluid and make sure to reset everything in INPA so it can re-calibrate to the new solenoids. The accelerator to the floor for 30 second thing never did squat for me.
I had 7 quarts of new fluid on hand and it wasn't enough. I had to use a quart or so of the old stuff (which had been changed a few weeks ago so it wasn't so bad) to finish filling it up.
Old 02-09-2017, 03:34 PM
Laura1234 Laura1234 is offline
I need help too
My car is saying hydrolic pressure sensor
Wont change gears
Old 02-10-2017, 05:48 AM
rvsixer rvsixer is offline
Mein Auto: E60 530i
Laura1234, the ZF transmission uses fluid pressure sensing (among other things) to control shifting. I am thinking a bad pressure sensor might cause that problem. Now, can that sensor be replaced? If it can be done in the field, a very good, trusted independent shop can do the work and also advise you if it would be better to do more work based on how far along the transmission is in it's service life.
Also, download, print, and read this: http://www.bimmerfest.com/forums/sho...d.php?t=731460
Mike in Minnesota
2004 E60 530i
Old 10-29-2012, 01:00 AM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
You are the man . Question, apart from resetting INPA was there any other recoding required from $ealership? My local indy has told me if the solenoids are changed, it would need recoding.
Also, in your video I could not see how did you remove the sealinng sleeve. If you remove the valve body, do you have to pull the sealing sleeve from outside the transmission body or just disconnecting the wiring harness is enough and the sealing sleeve just comes out along with the valve body.
Sent from my Android Bug
Old 10-29-2012, 05:02 AM
DIY'er
Nope, no re-coding. Just reset the transmission adaptations. Technically when ZF builds these transmissions they do flow testing on each solenoid individually and program the computer with that data, so it has the most information possible about that solenoid. However, usually new solenoids are close enough that the range of adjustability that the transmission has is wide enough to make them work just fine. It just may take a week or two of driving for it to figure it all out. There are no serial numbers or anything on the solenoids that the computer can read, so it doesn't really know if they're new ones or anything like that.
Sorry, after I stripped that pan bolt I forgot about the video for a bit. Yes, you have to remove the sleeve. It was so cramped up in that area, that I actually couldn't get it completely out of the car--I could only get it out of the transmission then just left it up in the car wherever it was and called it a day.
There's a transmission mount at the rear of the tranny that if I could have removed, I think I could have gotten the sleeve out. I didn't have female star sockets on hand though so I couldn't get it out, but to answer your question, YES it has to come out.
Old 11-08-2012, 05:19 PM
kskane's Avatar
From DownUnder
Thanks, one more question, does CTSC actually provide a guide how to replace the solenoids on the valve body? Is it simple un-screw and screw back in or can you share any guide you followed? That would be much appreciated as I am planning to change all my solenoid in my next ATF oil change.
Old 11-08-2012, 05:28 PM
DIY'er
They included very basic instructions, but it was just like "remove mechatronics", "remove solenoids", etc. nothing that will really give you a step by step.
Basically there's a retainer plate (you can see it in one of the pictures towards the end of the video, that has maybe 8 screws on it and runs the length of the solenoids. That is all that holds the solenoids in. The solenoids have o-rings on them that seal pretty tight to the holes they are in, so it takes a bit of a yank to get them out, but ultimately that's it. They don't screw into the valve body or anything like that
I wish I could have gotten a good video of swapping them--that was the part I wanted to record the most but I ran my memory card full on accident unfortunately.
I found a video on youtube that shows disassembly of a very similar mechatronics unit (maybe the 5HP or something like that?). I'll post it when I find it.
Here it is (below)
Note that the wiring harness doesn't really exist on the 6HP. It's a big plastic piece with connectors that line right up to the connectors on the solenoids, so that part is nothing like it. But removing the actual solenoids is the same.
And obviously ignore the whole taking the valve body apart part--no need to do that to change solenoids.
Old 11-14-2012, 03:31 AM
kskane's Avatar
From DownUnder
Here it is (below)
Thanks schpenxel, one more question in relation to INPA. I am not very confident with INPA, but following your post, I got a cable and somehow got the INPA 5.0.1 with EdiABAS 6.4.3/7 working. Can you please tell me exact steps how to clear adaptive transmission memory? In my scripts, under transmission, I can only see how to read and clear the errors in transmission, but how do I clear the adaptive transmission memory? I would really appreciate the information.
Old 10-29-2012, 07:33 AM
dolfan13's Avatar
dolfan13 dolfan13 is offline
Mein Auto: 545i
Very cool Thanks!!
Old 10-30-2012, 02:53 PM
hooch999 hooch999 is offline
Mein Auto: 550i
where did you get the solenoids from? What's part number?
Old 10-30-2012, 02:54 PM
DIY'er
http://www.thectsc.com/index.php?p=p...d=36&parent=52 is where I got them for mine. Email them if you're unsure which to buy.
Old 12-07-2013, 04:07 PM
6ICEMAN9's Avatar
6ICEMAN9 6ICEMAN9 is offline
Mein Auto: 08 550i
What's the difference between "E-shift", and "M-shift?"
Old 12-07-2013, 04:09 PM
DIY'er
E-shift transmissions basically have no physical connection between the shifter and transmission--it's all electronic. I believe there are an extra solenoid or two on these cars to engage/disengage the parking paw
M-shift transmissions are like most cars where the shifter is actually connected to the transmission
Old 01-29-2013, 05:24 PM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
Semper Fidelis Teufel Hunden!
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 01-29-2013, 05:37 PM
Vapiano's Avatar
I need to have some sort of code before I can get the warranty company to pay for changing out the solenoids. I have a slight delay in reverse and the back and forth shifting from 5th-6th; heck I might just do it on my own. How much is the solenoid kit and what is the process of getting the right amount of fluid back in the tranny?
Old 01-29-2013, 05:41 PM
DIY'er
It varies depending on the exact model, but I paid $400 and some change for it.
I would replace fluid and pan/filter while you're at it. Total probably 700-800 if you do it all?
For oil level:
  • Remove fill hole plug from side of transmission
  • With car off (and transmission pan/drain plug in), fill through fill hole until no more oil can be added without it flowing out. I bought a little hand pump from Advance Auto to do this for $12
  • Install fill plug partially to stop oil from coming out (just in case)
  • Start car
  • Remove fill plug
  • Add fluid until enough is in the transmission that it slowly dribbles out
  • Measure transmission temperature either via INPA or some sort of thermometer. When transmission hits 104*F and fluid is still slowly dribbling out, replace fill plug. There is a temperature you can't get over, I believe it is 120*F. If you go over that temperature, you have to wait for everything to cool back down and start over.
  • Tighten fill plug
  • Done
RESET ADAPTATIONS BEFORE DRIVING!!!
And no, being under the car while it's running is NOT a fun job. I would also recommend a few heavy rags to insulate the back of your hands from the exhaust pipes that go right by that area (or did on mine anyways). Ask the back of my hands how they know..
Old 01-29-2013, 05:52 PM
Vapiano's Avatar
For oil level:
  • Start car
  • Remove fill plug
  • Tighten fill plug
  • Done
Great! Thank you. Regarding INPA to check tranny oil temps and resetting adaptations; is there a kit that I can purchase online? Thank goodness I have a friend who owns a service shop; he should have INPA come to think of it!
Old 01-29-2013, 06:12 PM
DIY'er
Cable that works most consistently is here:
http://www.one-stop-electronics.com/...&product_id=16
It comes from China and takes about two weeks to get though, so that part sucks.
INPA here:
http://bmwcoders.com/forum/bmw-gt1-o...-software-328/
Pictures don't work, but you can follow directions without them. Make sure to follow all of them.. especially the last part starting with
"After restart:
Open :\Referenz2006\INSTALL\Instprog.exe
Click OK:"...
etc.
Old 01-31-2013, 01:03 AM
amennrahh's Avatar
amennrahh amennrahh is offline
BM6er
Mein Auto: 2005 BMW 645ci
For oil level:
  • Start car
  • Remove fill plug
  • Tighten fill plug
  • Done
I would say that being under the car while its running was the worst. lol Talk about HOT!
SEMPER FIDELIS
Old 10-20-2013, 07:03 PM
cowboyjer cowboyjer is offline
Mein Auto: 2000 528i
torque specs
I'm working on replacing solenoids. Does anyone have torque specifications for the solenoid retainer clip, and for the black plastic control unit? I have specs for the valve body and pan bolts.
Also, the sealing sleeve will definitely not come out. I'm thinking about taking the orings off of the new sleeve and installing them on my old one. I need someone with small hands to put the sleeve back in and plug it in.
Old 10-20-2013, 07:48 PM
DIY'er
Yup! The second time I did it I found that putting some heavy gloves on the exhaust in the area your hand will be basically up against made it better to deal with--burned my hand the first time
You have to take the mount off at the rear of the transmission. You'll need torx "E" wrenches to do it--I had the same issue, and didn't have the right tools at the time, so I had to put my old one back in. I would not try to switch the seals around personally
Sorry, I haven't been able to find a torque setting on those
Old 10-22-2013, 04:14 AM
pcy pcy is offline
Mein Auto: '06 530i, '07 C280, ML320
With the use of long-reach pliers, and few chosen words... you will be able to replace the sleeve. :-)
545i, 6hp19, 6hp26, e60, mechatronics, solenoids, valve body
