Old 11-01-2012, 09:27 AM
los2much's Avatar
los2much los2much is offline
Mein Auto: 745li
My 745li is idling up and down at 1500 rpm
It dont idle like this when sitting in park but only as you going down the road and its at 1500rpm where it goes up and down. If anyone ever experienced this please help me out on the fix and please be detail thanks.
Old 11-01-2012, 10:06 AM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
It's your tranny acting up.
Old 11-15-2012, 04:39 PM
cmpcpro cmpcpro is offline
Mein Auto: Nothing
Well I have been having this issue every morning when I take the car out of the garage.. It happens for the first mile or so then goes away.. I couldn't tell if it was the tranny acting up or the motor running weird.. well today I threw it in M mode while going down the road in 5th having the issue and it remained, it's not the tranny shifting/searching, it's something with the motor. Now I don't drive hard, but I have no idea how the PO drove.. anyway, I noticed when I fired it up the other night when it was cold I could hear the exhuast while I was leaning in the trunk and it sounded a tad bit rough and I think I could smell a little fuel.. anyway, since then I have replaced the stock plugs which were shot with new Iridiums. The coils look to have been done around 07 because they all had an 07 date (MM/DD/YY) of the same 07 date.. I took the MAF out the other night which looked brand new, but I cleaned it anyway.. any other ideas?? Thanks guys!!
Old 11-15-2012, 06:41 PM
DFEL750I's Avatar
DFEL750I DFEL750I is offline
Mein Auto: 750I
Guys if this is not happening when idling in neutral or when stopped in drive and is only happening when the car is coasting then its your torque converter. Check fluid level in the tranny...if it is properly filled then if you want to fix this issue then the torque converter has to changed.
Basically when the engine is not under load and the car is allowed to coast the wheels are freely spinning and the driveshaft is moving faster than the engine flywheel. The torque converter is responsible for doing torque manipulation to counteract that speed difference and keep the engine RPM constant. When the torque converter is not working right it will not do its job properly and therefore you will have the idle fluctuate.
Old 02-11-2014, 11:13 AM
ssdriver27 ssdriver27 is offline
Mein Auto: 2003 745LI Alpine White
My guess is what he said. That or pvc related or vaccum related.
2001 Camaro Z28 custom built and custom turbocharged 600+WHP @ 14PSI. (SOLD)
1996 Maxima GXE (commuter/camping/Dogs are coming with, car)
Old 02-11-2014, 11:34 AM
oldknife oldknife is offline
Mein Auto: GTR / 2005 BMW 745i
I just dropped my car off at the shop for this issue, I changed ccv and new plugs.
Going to have the fuel filter replaced as well ... maybe its a coil or a injector or MAF.
I hope they figure it out. Will let you know what they discover.
Old 11-01-2012, 10:18 AM
Khabar Khabar is offline
Mein Auto: 745i 2005
I think it maybe flywheel getting stock.
Old 11-01-2012, 10:20 PM
los2much's Avatar
Mein Auto: 745li
it has no problem changing gears
Old 11-02-2012, 08:48 AM
I know I have the same problem. it happens only when it time for trans to downshift,but if u use manual mode it work just fine. Take a look at flex disk maybe it broken
Old 11-02-2012, 10:56 AM
BimmerBrad7's Avatar
BimmerBrad7 BimmerBrad7 is offline
Mein Auto: 05 745 LI, 05 Acura RL
My car does exactly the same thing. Its pretty annouying. Same as you tranny shifts smooth as silk. But if im coasting down the road foot off the gas the rpms will go up and down slightly. Can't figure it out.
2005 BMW 745 LI Sapphire Black
22's, AC Schnitzer Kit, H&R Lowering Springs, Tinted tails and Signals, AC Schnitzer
Carbon Door Pillars, Cross Drilled and Slotted Rotors, Tuner Mod, Tinted Windshield,
30% Tint all the way around, and some other stuff I forgot.
Old 11-04-2012, 08:53 PM
los2much's Avatar
Mein Auto: 745li
I wish some experience techs would chime in.
Old 11-12-2012, 06:28 AM
MR 7 MR 7 is offline
Mein Auto: 745Li
Try the infamous PCV valves or also known as crank case ventilators. I have attached a link so you can see what they look like
http://www.ebay.com/itm/OEM-BMW-E53-...-/160688315458
Old 11-12-2012, 08:10 AM
It is good thing to change them but it has nothing to with the problem
Old 11-14-2012, 09:41 PM
Bryanycw Bryanycw is offline
Mein Auto: 735I
Hello, I have same problem even changed MAF Sensor....really annouying, hope can have some suggestion & solution here.
Old 11-14-2012, 11:30 PM
Mein Auto: Nothing
I have same issue, only when car is cold.. for first few minutes of driving, if it drops down to 1200rpm or so it will move up and down, after it warms up its gone.. I first thought tranny, but I am wondering it it has to do with motor.. I think maybe motor is not running at 100% and is making the tranny shift "off" maybe a little power short? who knows, really discouraged with these cars after reading nothing but problems with everything..
Old 11-15-2012, 07:18 PM
Mein Auto: Nothing
This is not happening when at idle or coast.. When the car is cold for the first mile or so if you give it throttle everything is fine, but if you are feathering to stay at speed limit the tranny will drop into such a high gear the car will run at 1200RPM, and that is when I am getting the fluctuation.. while giving it throttle, if I let off gas then it goes away..
Old 02-11-2014, 08:52 AM
blakey2000 blakey2000 is offline
Mein Auto: 2001 x5
me too
Did anyone ever figure this out? same issue . Car lightly surges up and down while triving, it shifts fine. Doesnt do it until warmed up. blakeyatwork@yahoo.com any ideas?
It isnt throwing any codes....
2003 745i
Old 02-11-2014, 04:35 PM
Joe750's Avatar
Joe750 Joe750 is offline
Mein Auto: 750li
I have the same issue ! Never made a big deal about it but it does bug me !
Old 02-26-2014, 01:02 PM
Busarider Busarider is offline
Mein Auto: 745LI
It seems that car has learnt drive adaptations from the previous owner, try resetting your transmission using the method described in the forum first.
Does this happen when you use diffrent set of keys? has the software been updated for the transmission? check with the dealer.
Old 02-27-2014, 12:39 PM
CarFanatic CarFanatic is offline
Mein Auto: BMW 750LI 2006
i had the same issue , have the dealer run the code you'll have a misfire and usually you need to have the head replaced . I had mine replaced and its perfect but remember if you do nothing about it. it gets a lot worse literally my car would galap ...
Old 03-07-2014, 01:55 AM
erniejazz erniejazz is offline
Mein Auto: 745il
I have the same issue cruising at 38-40 mph. Having the Maf cleaned, new fuel filter, new air filter, new ccvs.... should have it back tomorrow. Also new battery and registration. Hoping this helps. Secondary air was very dirty so maybe choking a bit. Cleaned that using the AGA tool. Who knows.
Old 09-17-2016, 06:54 PM
05_745li 05_745li is offline
Mein Auto: 05 745li
Hey when you used the Aga tool for the secondary air deal did you do both side or just one of the sides? If you did and how did you get the drivers side done?
Old 09-17-2016, 06:58 PM
Mein Auto: 05 745li
How did you clean the drivers side secondary air system with the AGA tool?
Old 03-07-2014, 05:06 AM
los2much's Avatar
Mein Auto: 745li
have anyone figured out the fix for this problem?
Old 03-07-2014, 06:51 PM
MichealY60 MichealY60 is offline
Mein Auto: 745I E65
Mine does same thing. even worse coz the gear change is really slow when I push the gas hard like around 5000 rpm. it will take 3? 4? second to change to higher gear. And feel its get worse and wores
