Old 11-04-2012, 12:12 PM
mafabix mafabix is offline
Mein Auto: BMW 318i
Help: Is it the shocks?
There is a sound coming from the rear on the driver's side when I start to accelerate or when going around a bend. It seems like some loose object rolling around in the trunk. I checked my trunk and everything is locked down. I thought my shocks were gone and so I checked into a garage. However the mechanic said both my shocks are still fine. He added what he called "spacers" on the mounts of both shocks and said all would be fine. His reason was that the sound was caused by the springs around the shocks. I now do not know what is causing this. A search of the forum has not helped.
Old 11-04-2012, 02:55 PM
elhombre's Avatar
elhombre elhombre is offline
Mein Auto: 2003 325i, '99 e36 328is
I assume your 318i is an e-46.. Although I have not suffered this malady, many e-46 owners have- check your rear subframe attach points, check for cracks in the floor. BMW settled a class action lawsuit with e-46 owners concerning floor failures. Check the wiki here to see if this may be what is affecting you.
Old 11-04-2012, 07:46 PM
QAfred QAfred is offline
Mein Auto: 328i, 330ci, R1200C
I don't know of any suspension noises that sound like something rolling around. Did you remove your back seat to see if something is under it rolling around? Cracked subframe is usually a clunk type of noise, like the sound of a worn dif bushing from what I have read.
Old 11-05-2012, 10:07 AM
mawana's Avatar
mawana mawana is offline
Mein Auto: e46 ZHP
^^^ this!
"Common sense is the collection of prejudices acquired by age 18." ~ Albert Einstein
BMWCCA 405578
Garage
1. 2015 k46 S1KRR
2. 2008 e90 M3
past: 2003 e46 ZHP
Old 11-05-2012, 08:15 AM
Mein Auto: BMW 318i
Yes, the 318i is an e-46.
I will remove the back seat and check but I would be surprised to find anything. This sound just started out of nowhere. The sound is like there is something loose somewhere in the back. It is like a clunk. However it only occurs when I accelerate or when the car is going round a bend and then it is quite loud. The mechanic said that the sound comes from the barrel spring around the rear shocks. He added some rubber spaces at the upper end of the rear shock mounts and assure me the sound would be gone. It did disappear for a couple of days but then came back.
I thought of replacing the shocks but the mechanic thought it would not solve the problem. Could the barrel spring be the problem? Has it become weaker? What is a cracked subframe? If it is the subframe that is cracked, how do I verify this? Our roads are pretty rough.
Old 11-05-2012, 08:25 AM
Mein Auto: BMW 318i
Furthermore, after the mechanic added the spacers, the car handles a lit bit oddly. Could the spacers be affecting the vehicle dynamics?
