Old 11-08-2012, 07:24 AM
mnbmr mnbmr is offline
Mein Auto: 2003 530i
question about 2003 530i manual tranny shifting from 1st to 2nd gear
Hello all, I am a new 2003 BMW 530i owner and have a question about the shifting on my manual 5 speed. I have owned the car for a few days and have been driving it aggressively as I am so stoked to own it.
When shifting from 1st to 2nd gear the car seems to EASE into second no matter how hard I try to get it to change gears quickly. If I am revving high rpms and let out the clutch quickly the rpms just gradually ease down. The car moves forward with pretty good pull, its not as if it is lagging, but just not the abrupt acceleration I would expect.
At first I wondered if my clutch was slipping, but I did a test of trying to start from a stop in 3rd gear to see if the car would stall or the clutch would slip - a friend recommended I try this test. The car stalled, which he said indicated the clutch is fine.
My next thought was that BMW had installed some kind of limiter that keeps the car from spinning the tires and sliding out of control if you try to shift to hard. Is this right? Am I over revving from 1st to 2nd?
The car is a 2003 530i sport (E39) with a Dinan stage 2 chip and Dinan cold air intake.
Any advice is greatly appreciated. Thanks
Old 11-08-2012, 07:46 AM
mbell666 mbell666 is offline
Mein Auto: e39 2002 540i6
have a search for CDV (Clutch Delay Valve) and then have a look under your car. It may have been removed from your car or not.....
An e39 is like a beautiful wife, needs constant attention, lots of money, lets you down at the worse times but you’d never be without it.
Old 11-08-2012, 08:05 AM
Thank you mbell666. That seems like a great place to start. After doing a search on the forum for clutch delay valve I now have a lot more info to go on. Much appreciated. I even learned something about shifting into reverse that I can share with my wife who was having a hard time with it!
Old 11-08-2012, 11:05 AM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Don't forget to change the trans and diff lubes; they've probably never been changed.
A good quality synthetic trans lube will improve the shifting.
Old 11-08-2012, 11:22 AM
ndz ndz is offline
Mein Auto: 00 528i/5, 99 540iT
Sounds like normal function of the CDV. Some remove it. I left it on.
Tell us what you learned about R?
99 540iT - Merlot Truckster
00 528i/5 - Grüen Arrow
93 740i - Grün Hornet (sold)
00 740iL (R.I.P.)
Old 11-08-2012, 12:09 PM
edjack: thanks for the note about trans and diff lubes. I will look into changing those as well.
ndz: in another thread about CDV a forum member named Fast Bob posted the following about the transmission being an issue for the 1st to 2nd gear shift and then follows with a comment about reverse.
"The CDV inhibits clutch feel mostly when first starting off from a dead stop.....it makes the engagement point sloppy & unpredictable. Once you`re under way, you only need to depress the clutch maybe halfway to shift to the next gear, and the CDV is less of an issue.
Also, that "difficult" one-to-two shift is *not* a CDV problem, it`s a trans design problem. There`s a HUGE gap between first and second, where the RPMs fall off by 42% (the equivalent of falling off a cliff), and there`s nothing that will cure that except *practice*, experimenting with different shift points until you find a combination that works for you.
As far as the reverse issue goes, tell her to put the trans in any forward gear *before* attempting to engage reverse, and it will go in much easier (especially in cold weather)"
Old 11-08-2012, 01:24 PM
jygesq jygesq is offline
Mein Auto: 2015 Audi S4. BMW is gone
rev limiter in engine will shut dowm temporarly
engine if you exceed redline shifting ,BUT it will not save engine is you make an error in downshifting so be careful .
Old 11-08-2012, 01:28 PM
Thanks. I'm sure that isn't the issue though. I'm not pushing it THAT hard. We are talking maybe 5,000 rpms - not 6 or 7k.
clutch issues, e39 shifting issues, manual transmission, shift lag, shifting, shifting questions
