E36 (1991 - 1999)
Old 11-11-2012, 01:28 PM
Benjamin99 Benjamin99 is offline
Mein Auto: 1998 318i Sedan
HID, Fogs, AE Rewire
I need to preface this by stating that I know this is probably overkill.
However, I got a great deal on a set of headlights with AE's, fog lights (car is not pre-wired for fogs), euro fog light switch, and HID kits for both low beams and fogs. I'd like the AE's coming on with the alarm arm/disarm (using the dome light circuit) and also with the ignition power to use as "DRL's". I have seen information on purchasing a relay kit for the HID's and the AE's to make these work like I want, to avoid any error codes, and to re-route power to HID's from battery directly. Rather than just piecing a bunch of random relay kits and harnesses, I decided to just re-wire it up myself.
I am currently in the planning stage. I will be using GXL wire, WeatherPack connectors, and a Bussmann 15303 relay/fuse panel. I came across a great website to help plan out some complicated wiring beforehand.
http://www.circuitlab.com
Here is a copy of my schematic I put together.
https://www.circuitlab.com/circuit/d...hting-circuit/
Once I receive my fuse panel and the weatherpack connectors I ordered (already had the wire, etc), I will begin wiring this up - maybe I will do a DIY. Link to fuse panel below.
http://www.waytekwire.com/item/46344/
Hopefully this will help someone out looking to do something similar. Take a look, if you see any problems with my "plan", please let me know!
And again - yes I know this is overkill, but I am enjoying the process and like to have a clean/factory look, so I hope this will help achieve that.
***Well I was trying to include links to my parts and schematics, I'll have to figure out how to do that around my restrictions?
Updated schematic - decided to add separate relays for the HID's so that I do not have any splices in my terminal, not a fan of "Y" splicing out of a terminal. Also, decided to go with a bussed relay/fuse panel Bussmann 15303-5-2-4 so that I only have 1 power wire running into the panel instead of 5 individuals.
https://www.circuitlab.com/circuit/p...ing-circuit-2/
Old 11-11-2012, 03:41 PM
Jakobie1086's Avatar
Jakobie1086 Jakobie1086 is offline
that other kid
Mein Auto: 92 325i and 98 328i
Looks good. I did a very similar thing when I re-did my ignition, added engine electric fans, heated seats, and gauges. Only difference was I hand drew my schematic and I built my own fuse panel
Old 11-12-2012, 12:23 PM
This is good practice for me, never have been real good w/ electrical work.
