E30 (1982 - 1993)
Old 11-12-2012, 12:24 PM
WickedFast.Inc WickedFast.Inc is offline
Go Fast or Go Home
Mein Auto: 1989 325I
Afm
89 325i how do I correctly adjjust my afm
Wicked Fast Entertainment
Old 11-12-2012, 01:31 PM
Newman271's Avatar
Newman271 Newman271 is offline
That Guy
Mein Auto: 99' 540i M-Sport
You have a air/fuel meter? Why do you think the afm is reading wrong?
Without knowing what your air fuel ratio is you really can't adjust it. I've read to just buy another one. I bought 3 from a junkyard for 5 bucks a peice.
1999 540i M-Sport
Silver/Black
Still fresh and Minty
1985 335i
Black on Black coupe 5spd
R.I.P
1979 Trans Am 10th Anniversary
#16 of 5,683 made
KOI Import Parts-- 513-771-7777
Old 11-12-2012, 03:20 PM
Go Fast or Go Home
Well is not bad but my idle valve is bad so the person before me **** with it so it would stay running at idle
Old 11-12-2012, 03:21 PM
Go Fast or Go Home
Air flow meter mass airflow meter before the intake my bad ive seen it wrote afm and mam
Old 11-12-2012, 04:55 PM
BMWFatherFigure's Avatar
Old School
I wood go mannyfold leeks bee forr I tried to ajust setting agin. (How is my Texas spelling?)
Current:
E38 Parts Car
Previous:
Old 11-12-2012, 04:56 PM
downhiller's Avatar
livin large
just use the idle adjustment on the throttle body. afm/maf just tell the computer how much air is being pulled into for timing and injector pulses. at least to the best of my knowledge, theres not much you can adjust if anything on a afm. maf you cant adjust it, i know that one.
Old 11-12-2012, 06:46 PM
Go Fast or Go Home
Mine has a flap inside and if you take the black cover off the top there is a black plastic gear with the number 500 on it every 15-20 teeth it is hooked to a metal bar that runs over a metal stip floats actually and i can adjust it so the starti g position of the flap is different
Old 11-12-2012, 06:47 PM
Go Fast or Go Home
I also found that if i make the starting position near closed i get low acceleration if i put it say halfway i can get 0-60 in like 4-5 sec rather then 7
Old 11-12-2012, 11:32 PM
Nick323's Avatar
Nick323 Nick323 is offline
Nick's Toys
Mein Auto: 323i E30 2-door
Post AFM adjustment
You have got a VAF that is easy to adjust on a Dyno
Run it a WOT @ 4000 RPM and get somebody to turn the plastic gear (with its stop temporarily removed) to read about 13.2 AFR or 3 to 3.5 CO then arrest the gear again
I am sure the manual (which fits in 3 ring binders) also tells you something, should you not be able to do it the way I usually do it.
MAP sensor measures maniold vacuum and is best tuned with a Unichip
MAF sensors are the best as they measure the actual air mass entering the engine. These can be "tuned" with some shunt resistors, should you not be able to afford a Unichip.
If you do not have the availiability of a Dyno, you can ask somebody expandable to kneel on the fender whilst you floor it down the road in 4'th &
I know I am going to get sued & I do not care as our judiciary has ground to a halt years ago
Don't take life too seriously; no one gets out alive !
1984 323 currently being resurrected from the ashes
Old 11-15-2012, 11:23 PM
tim96 tim96 is offline
Mein Auto: bmw e30 320i
I may be wrong but..
The screw on the afm is for air / fuel ratio at idle and should only be adjusted while monitoring air / fuel ratios
There is no idle adjustment screw on the throttle body, just a screw which controls closed position of the throttle (which sits just passed right angle to the throttle body).
The idle is controlled by the idle control valve. If you open your throttle slightly from closed you should hear the idle control switch 'click' and 'click' again when you release the throttle. That is how the car knows whether it should idle the engine.
It is not uncommon for people to adjust the screw on the throttle body thinking it is the idle screw, this is incorrect practice.
http://www.pelicanparts.com/bmw/tech...leshooting.htm
