Stomp test - Bimmerfest - BMW Forums
E34 (1989 - 1995)
Old 11-12-2012, 03:11 PM
e34_spangler's Avatar
e34_spangler e34_spangler is offline
e34 User
Mein Auto: e88 135i
Stomp test
If I take a video of me doing the stomp test could someone tell me what the blinking light comes out to be like which codes
Sent from my SCH-I535 using Bimmer App
Old 11-12-2012, 03:17 PM
BMR_LVR's Avatar
BMR_LVR BMR_LVR is offline
Humble E34 lover
Mein Auto: 1992 525i
Yes we can. I'm getting ready to leave for a while, but there are many here who can help you read the codes.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-12-2012, 03:25 PM
e34 User
Mein Auto: e88 135i
Ok great!
Old 11-12-2012, 04:10 PM
Banned
Mein Auto: car
There are videos on youtube that show the stomp test in action.
Old 11-12-2012, 04:26 PM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: Sig
He's asking for us to read his codes for him. Not how to do it
1995 525iA 250k mi
2003 350Z 90k mi FOR SALE
2014 F-150 9k mi
Instagram: @Titan_E34
Snapchat: Titan_E34
Old 11-12-2012, 04:31 PM
Banned
Mein Auto: car
Oops my bad.
Old 11-12-2012, 06:11 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
Ok post the video we will try.
Old 11-12-2012, 07:31 PM
e34 User
Mein Auto: e88 135i
Here it is! Thanks in advance
Old 11-12-2012, 07:39 PM
BMR_LVR's Avatar
Humble E34 lover
Couldn't open it.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-13-2012, 04:49 AM
e34 User
Mein Auto: e88 135i
Try that!
Old 11-13-2012, 06:28 AM
BMR_LVR's Avatar
Humble E34 lover
Still doesn't work for me.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-13-2012, 06:30 AM
Banned
Mein Auto: car
www.yousendit.com would be a far better online archive.
Old 11-13-2012, 07:24 AM
Monsignor's Avatar
Mein Auto: Sig
Fixed
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-13-2012, 04:35 PM
luckydog's Avatar
Fixed
I get 1444 Code 1444
= No more faults, No corrective action necessary
Old 11-13-2012, 05:00 PM
BMR_LVR's Avatar
Humble E34 lover
I concur Captain (said in my best Denzel Washington voice)
To OP, keep in mind that the 92 model did not have the ability to check and report (via the stomp test or code reader) all features. For example, it does not have the capability to check fuel injectors or coils just to name a couple. I had a bad coil recently on my E34 and there were no codes for it. I reviewed the Bentley and discovered what I just mentioned above. Take a close look at chart for codes in the Bentley and you will see what I'm talking about. Will take a look at your problem again and give some more thought to it.
Umhhh ..... what was the original problem again?
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-13-2012, 08:27 AM
e34 User
Mein Auto: e88 135i
Fixed
Thanks!
Old 11-13-2012, 04:21 PM
e34 User
Mein Auto: e88 135i
Anybody?!
Old 11-13-2012, 07:10 PM
e34 User
Mein Auto: e88 135i
That's explains no faults cause the damn thing wont start it cranks and will run on starting fluid for like a few secs.
Old 11-13-2012, 07:11 PM
Monsignor's Avatar
Mein Auto: Sig
Fuel pump or fuel pump relay if it cranks without firing. Almost certainly.
I had the same issue. Threw a new battery on it and it fired immediately. Food for thought.
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-13-2012, 07:42 PM
BMR_LVR's Avatar
Humble E34 lover
I agree that if it starts on starting fluid, it is fuel delivery related. I also agree with Joe above. Just remember to also check the fuel pump fuse if you have not checked it already. Also, a clogged fuel filter can cause no-starts. If yours hasn't been changed in a long time, consider that.
Check the Bentley manual on jumping the fuel pump relay (posts 30 and 87) to supply constant power to the pump. It the pump is not running, remove the connector and check for power to the connector. If you have 12v, then the pump is bad. If you hear the pump running, then the problem is the relay.
Figuring out no-starts are not too difficult if you take a methodical approach .... and follow the Bentley manual.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-13-2012, 07:55 PM
e34 User
Mein Auto: e88 135i
Yea I figured it was fuel system just wanted to see what you guys thought my dad insisted it was the ecu but I completely disagreed with him like always hhahah
Old 11-13-2012, 08:02 PM
BMR_LVR's Avatar
Humble E34 lover
Generally, if the car runs with starting fluid, it is not usually the ECU (we call it DME around here ), especially if it runs well, meaning not skipping, popping, bucking etc.
Do not run the engine long on the starting fluid. It is hard on the internals. Once you narrow it down to fuel delivery, which you have done, there are a limited number of components. All have been discussed here except fuel pressure regulator, but it doesn't really sound like that is the case.
It should be the (check in order of ease and least cost):
1) Fuel pump fuse
2) Fuel pump relay
3) Fuel filter
4) Fuel pump
Let us know once you figure it out. I have a very high degree of confidence that you will figure it out and fix it.
Steve
1991 735i - Sold
1992 525i - Sold
1995 325is - Sold
2000 528i - Sold
Old 11-13-2012, 08:16 PM
Monsignor's Avatar
Mein Auto: Sig
Originally Posted by bmr_lvr View Post
let us know once you figure it out. I have a very high degree of confidence that you will figure it out and fix it.
+1
1995 525iA 250k mi
2014 F-150 9k mi
Snapchat: Titan_E34
Old 11-13-2012, 09:02 PM
Mein Auto: 1989 525i M20B25
Code 1444 and all is well!!!
Read this too:
http://forums.bimmerforums.com/forum...&highlight=m20
Old 11-14-2012, 05:10 AM
e34 User
Mein Auto: e88 135i
Thanks a lot guys!
