Old 11-12-2012, 08:27 PM
dcuellar90 dcuellar90 is offline
Mein Auto: 2005 bmw 545i
05 545i increased emissions help!!
i had increased emissions light came on and the car was shaking also said overload may damage catalytic converter. i had it checked out and replaced 2 ingition coils that was miss firing and spark plugs. it was working fine then it came back on and shakes a little bit again and now its missing on 5 and said something about the secondary air something? i used the inexpensive spark plugs also, what do you suggest if anything , any advice will help thank you
Old 11-13-2012, 08:26 AM
jfer34 jfer34 is offline
Mein Auto: 2004 545i
hey i have the same light that just went on, no shaking in my engine though. i have no idea why the light is on and haven't had the time to get it checked out, i just replaced a hose causing an anti freeze leak i don't know if that has something to do with it but if anyone has any insight on this it would really help. i too have an 04 545i.
Old 11-13-2012, 07:28 PM
luckydog's Avatar
luckydog luckydog is offline
Lucky to drive a BMW
Mein Auto: 2006 M5///
When my car had the warning lt it was cracked secondary air hoses to the cats,also one of two secondary air valves was bad and had a air leak at its mounting point.And a small maf sensor was replaced too. the valves/or air pumps are under the front of engine on the M5.
Old 11-14-2012, 07:10 AM
Jaycal3's Avatar
Jaycal3 Jaycal3 is offline
Originally Posted by luckydog View Post
When my car had the warning lt it was cracked secondary air hoses to the cats,also one of two secondary air valves was bad and had a air leak at its mounting point.the valves are under the front of engine.
The valves are actually at the back of the motor against the firewall. One goes to each head. You are lucky if your issue is the secondary air pump and or valves and hoses. I changed all that and my issue is "carbon buildup in the heads"... a luxury car so technically advanced and yet an issue like this on an '04...really?! Its a $4-5k fix...
Deceased - 2004 BMW 545i Black/Auburn
-Sports Suspension, Premium and Cold Weather Package, Logic 7 Professional Audio, Rear Sunblinds, Adaptive Xenon Headlights, Active Steering, staggered setup on 124's, Aux Input
Mods
MTEC V3.0 AE's, Black and white roundels, Clear LED Side-markers, New Conti ExtremeContact DWS's, Charcoal Filter Delete, 35% Tint, 20%rear.
http://s705.photobucket.com/albums/w...%20BMW%20545i/
GARY BETTMAN IS A TOOL!
Old 04-08-2014, 09:12 PM
palm4143 palm4143 is offline
Mein Auto: bmw 530i
Hi i have a same problem.....can u advise.....
Old 04-08-2014, 09:23 PM
truckpilot545's Avatar
truckpilot545 truckpilot545 is offline
Mein Auto: 05 545i
I'd recommend a scan as well. I have 2A19-P0444 "evap canister purge control valve circuit open" and also get increased emission on my 05 545's Idrive. Soon I am going to change the DMTL, cause with DIS, I am able to activate and hear the tank vent valve on engine, plus i have already replaced the fuel cap. Your issue might be different, so you need the code. Don't forget to post your fix when you figure it out.
